plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old November 13th, 2007, 06:53 AM   #1
smcmanus
Canada
smcmanus is offline
Reverse Rotation on 120VAC Motor
Can anyone help me. I need to be able to Reverse a Single Phase 120VAC motor.
Old November 13th, 2007, 07:54 AM   #2
jrwb4gbm
United States
jrwb4gbm is offline
If the motor has a starting capacitor on it, there should be some leads marked T5 and T8. Swap these two wires. If they are not numbered,they may be color coded. There could (should) be a legend plate on the motor to identify which two leads to change. Look inside the wiring junction box also for information. If it doesn't have a starting capacitor, you may need to take it to a motor rewind shop to get it changed. In some instances, you can change ends of one of the windings internally to do this.
Old November 13th, 2007, 09:47 AM   #3
smcmanus
Canada
smcmanus is offline
Basically I need this motor to be able to run forward and reverse all the time. So if the motor does have a starting capacitor am I able to wire a motor starter relay for forward and reverse.
Old November 13th, 2007, 09:51 AM   #4
TConnolly
United States
TConnolly is offline
TConnolly's Avatar
Yes, if it has a starting capacitor you can wire forward and reverse relays. The capacitor is switched out of the circuit once the motor is started.
If the motor uses a shaded pole instead of a capacitor then you are probably out of luck, you will need to replace the motor with a reversible one.
__________________
True craftsmanship is only one more power tool away.
That's the beauty of processors, they don't have emotions they just run code - The PLC Kid.
Old November 13th, 2007, 10:20 AM   #5
rsdoran
United States
rsdoran is offline
rsdoran's Avatar
Look at these:
http://www.lmphotonics.com/single_phase_m.htm
http://www.patchn.com/motor_connections.htm
__________________
http://www.patchn.com Industrial Electrical & Maintenance @ www.patchn.com "Tell me and I forget, show me and I remember, involve me and I understand."
Old November 13th, 2007, 10:26 AM   #6
Electrically_Bound
United States
Electrically_Bound is offline
I know that some motors have a centrifugal switch that disconnects the start capacitor once it rotates past a certain speed. While it may be possible to wire the start capacitor for forward and reverse, I'm thinking that you may have to go to a stop before reversing directions.
Old November 13th, 2007, 10:38 AM   #7
Thomas Sullens
United States
Thomas Sullens is offline
U r right the motor has 2 at lease slow down until the governor kicks back in then it will reverse. This puts the start winding back into the circuit.
Old November 13th, 2007, 01:13 PM   #8
leitmotif
United States
leitmotif is offline
On any across line motor I would let it come to complete stop before reversing. The other thing to consider is heating and possible burnout of the motor as a result of frequent starting and stopping. If you are reversing every 10 second I doubt that motor will last long. If every 5 minutes it should be no problem.
Dan Bentler
Old November 15th, 2007, 10:22 AM   #9
72hdflh
United States
72hdflh is offline
Another option would be to use an A.C. drive that will accept 120 VAC single phase in and give a three phase output, such as these from Automation Direct. http://web1.automationdirect.com/adc...alog/AC_Drives
With this option you would gain the ability to ramp up/down, as well as vary the speed. On the down side you would have to change your motor to a three phase motor.
Hope this helps.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
OT: Motor Predictive Maintenance monkeyhead LIVE PLC Questions And Answers 21 August 15th, 2006 11:52 PM
Motor Equivalent Circuit (Long & Detailed) DickDV LIVE PLC Questions And Answers 36 February 12th, 2006 06:03 PM
OT - smooth motor rotation katratzi LIVE PLC Questions And Answers 21 January 31st, 2006 08:39 PM
Phase rotation and motor rotation testers leitmotif LIVE PLC Questions And Answers 2 August 14th, 2005 08:04 PM
OT - Slip Ring Resistor Calcs Kidblue LIVE PLC Questions And Answers 14 April 1st, 2005 09:19 AM
