plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old December 16th, 2007, 04:19 PM   #1
merlin00724
United States
merlin00724 is offline
traic question
did a search on triac outputs since i didnt know anything about them. learned alot, ecspecially about leakage problems and potential shock hazards and such. but what i havent fount yet is what the advatage to using one is versus an isolated relay output. is there one? or is there a condition in which you MUST use one? thanks as always.
Old December 16th, 2007, 04:31 PM   #2
BITS N BYTES
United States
BITS N BYTES is offline
Talking
The TRIAC output is a solid state device that if sized correctly for the switched load has an almost unlimited ON/OFF lifetime.
The RELAY is an electromechanical device. The mechanical components of the relay eventually wear out so it has a limited lifetime.
The frequency of switching the outputs needs to be evaluated for each application and compared with the published specifications.
From this one can determine if they will last the lifetime of the machine.
Old December 16th, 2007, 08:21 PM   #3
geniusintraining
United States
geniusintraining is offline
geniusintraining's Avatar
Also I have been told that the majority of the time that the triacs fail, they fail closed.... if you have it on a heater application this could be trouble... make sure that the over temp safeties are NOT in the PLC and will drop out the heater
__________________
www.PLCTrainer.net
PLC Trainers, Communication Cables and Automation Supplies, Allen Bradley ~ Siemens ... YouTube PLC help videos.. http://www.ind-concepts.com/Support_and_Downloads.htm
Old December 17th, 2007, 08:35 AM   #4
keithkyll
United States
keithkyll is offline
Another point is switching at zero-crossing. The triac will turn on and off when the sine wave passes through zero. A nice feature for resistive loads such as heaters because it reduces line noise. A relay switches any time, and can generate sparks when the contacts open or close.
Old December 17th, 2007, 11:13 AM   #5
merlin00724
United States
great info. thanks all
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Integrator Business Question mjrx LIVE PLC Questions And Answers 3 April 12th, 2007 05:37 AM
How to Ask Questions The Smart Way Ken Roach LIVE PLC Questions And Answers 14 March 26th, 2007 08:12 AM
OT..Question for Elevator Mike!! darrenj LIVE PLC Questions And Answers 35 March 30th, 2006 02:09 AM
Data Display Software Question markzb LIVE PLC Questions And Answers 3 March 15th, 2006 04:41 AM
Omron PLC and ethernetmodule question wwauters LIVE PLC Questions And Answers 3 February 21st, 2005 11:35 PM
