This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: Jul 2006
Siemens S7 FB41 cont c
Hello
I am trying to understand the operation and all the parameters required for setting up the FB 41 block, I have read the Siemens manuals but I am still a bit confused. My process is pretty simple, I have a room temperature transmitter (4-20mA) that controls the operation of a cold glycol diverting valve with 0-10vdc control and position signals. I have to control the room temperature at between -5degC to +10 degC (operator selects temperature setpoint via HMI). Any help would be helpful. Cheers Sean |
#2 |
Just search the forum for FB41, I'm sure you'll find a plenty informations...
#3 | |
Quote:
In the attachement you can see a test with PID project. There is an emulated heater process in it, so that you don't have to connect anything to see the PID work !!. U can use the Siemens PID Tool to optimize your process: If u use this, make sure that you can go online, choose ONLINE in this tool and open your DB41 (the online PID DATA). Then you can optimize grafically. |
#4 |
![]() Join Date: Oct 2004
If I remember correctly, if you require cooling instead of heating then set a negative figure in the proportional gain.
#5 |
hi there
I was trying the project attached by the combo Problem is am able to open the DB41 in the "PID Control" but cannot get online. Iam simulating the project in the PLCSIM. |
#6 | |
Ok
Quote:
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| siemens FB41 Level control | sirhiss2 | LIVE PLC Questions And Answers | 14 | April 3rd, 2011 08:22 AM |
| Siemens S5 and S7 Dual Masters for Profibus | daveswerld | LIVE PLC Questions And Answers | 15 | December 16th, 2008 02:15 AM |
| SCADA with S7 PLC by means siemens S7 PC/MPI cable | Andoni | LIVE PLC Questions And Answers | 4 | December 15th, 2008 07:04 PM |
| Siemens S7 ethernet protocol | fzhang | LIVE PLC Questions And Answers | 3 | May 19th, 2004 12:06 PM |
| AB panelView Plus MMI with Siemens S7 314 | iknowsomeplc | LIVE PLC Questions And Answers | 0 | November 18th, 2003 12:52 AM |
