plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 9th, 2008, 11:18 AM   #1
yam785
United States
yam785 is offline
yam785's Avatar
Servo Motor Y-1002-1-H00AA Encoder to Ultra3000i wiring.
I am working on a demo unit, which has a Y-1002-1-H00AA Servo Motor.
The demo unit originally had a Ultra drive 1398-DDM-005 controlling the above mentioned motor. This drive has a parallel type plug for the encoder feedback. I was tasked with changing the drive to a Ultra 3000i 2098-DSD-020-SE, which has a 15pin D-Shell. I have a cable with the 15pin D-Shell connector, but it does not plug into the cable coming from the motor encoder. I was told to splice the two cables. I just want to make absolutely sure of the pin-out, before I start. I am especially confused about where the "Hall" wires should be pinned to. As splicing the two will involve some time, I prefer to only do it once.
Any help would be greatly appreciated.
Old January 9th, 2008, 02:39 PM   #2
Gerry
New Zealand
Gerry is offline
When migrating from the older Ultra 100/200 (aka Electrocraft BRU) to the Ultra 3000 you need to purchase new feedback cables. Most of the motors had the Hall effect sensors installed, but the older drives didn't use them and so the old cables didn't include wires for them.
Old January 9th, 2008, 03:27 PM   #3
yam785
United States
yam785 is offline
yam785's Avatar
Thanks Gerry. I do have the new 15pin D-Shell cable for the ultra3000 drive, but I'm not sure what pins the 'Hall' wiring should go to.
Old January 9th, 2008, 08:10 PM   #4
abwiz
United States
abwiz is offline
abwiz's Avatar
Check out the following document from AB concerning this...
http://literature.rockwellautomation...m005_-en-p.pdf
To quickly answer your question, the Hall sensors on the motor get hooked to the commutation channels S1, S2, and S3. These sensors are used for commutation of the motor.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Encoder - Paralel wiring shanimi LIVE PLC Questions And Answers 7 January 26th, 2007 06:06 AM
Need encoder advise on used machine. helluvawreck LIVE PLC Questions And Answers 3 July 21st, 2006 03:40 PM
