plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 16th, 2008, 12:46 AM   #1
jeff s
United States
jeff s is offline
jeff s's Avatar
2 panelviews on same controller
Hello, can 2 panelviews with the same program in them, operate on the same controller?. Just curios about you thoughts and tips on doing this.
Old January 16th, 2008, 03:05 AM   #2
Gil47
New Zealand
Gil47 is offline
Gil47's Avatar
The user program can be the same on 2 panelviews on the same network BUT each panelview requires a seperate node address for communications so this automatically says that there is a difference between programs on each panelview, that little item of communications address.
Let us know the part number of your panelview, or panelviews, and the brand, and type, of controller, you may find there is a solution available for your situation that is not complex.
Old January 16th, 2008, 07:21 AM   #3
Flopro
United States
Flopro is offline
Flopro's Avatar
Absolutely-I'm commissioning a pair now. There can be issues if you are controlling logic by PanelView screen status or PanelView screen changes with the PLC. In that case each PanelView needs to have its own unique control/status words. So other than each PanelView's node/I.P address uniqueness, that Gil47 mentions, control/status words would be the other thing to consider.
Old January 16th, 2008, 08:32 AM   #4
widelto
Colombia
widelto is offline
widelto's Avatar
I think is not going to be a problem i got an aplication where a panel view 550 is connected to a compact logix 1769-L32E thru the serial port and at the same time i got a panel view plus 700 conected to the same PLC thru a ethernet switch.
__________________
My two cents.
Old January 16th, 2008, 10:41 PM   #5
jeff s
United States
jeff s is offline
jeff s's Avatar
Thanks for you input on this,I will gather more info as to what model of panel view and processor.again thanks for letting me know it can be done with out much trouble.
Old January 17th, 2008, 10:37 PM   #6
val_99
United States
val_99 is offline
If you are using alarms and reset them from Panelview, Don't forget to use remote alarm ack features in case. Just make a bit in PLC detecting ack from Panelview and use it as a remote ack bit in both units. Othervise, ones you reset an alarm from first PVl, it will be still remains in second one.
Old January 30th, 2008, 01:02 AM   #7
jeff s
United States
jeff s is offline
jeff s's Avatar
The processor is an slc5/04 with a 5" quickpanel junior connected to the rs 232 port. for the additional quickpanel should i get the AB DH+ interface card for the quickpanel and go that route or is there better options??
Old January 30th, 2008, 06:29 AM   #8
John Soltesz
United States
John Soltesz is offline
John Soltesz's Avatar
Quote:
Think, or learn, about how these communications work and you can answer that question. RS232 is one device to another device, so this port is currently used with the 5" QP. The only other way to communicate with the PLC is to use the DH+ which can go to multiple devices. Make sure all addresses are unique of course.
I think you can change the 232 port on the 5/04 to a DH485 but I don't recommend that since you have a 232 QP. I think you pay a premium for DH485 (if available) and DH+ with the QP.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
SLC Master Controller PID plcnovel LIVE PLC Questions And Answers 8 July 20th, 2009 01:14 PM
Retain Controller Data in an HMI tag (Allen-Bradley) Money4Nothing LIVE PLC Questions And Answers 16 July 19th, 2007 08:38 AM
What is this ? KTM Rider LIVE PLC Questions And Answers 28 September 10th, 2006 07:56 PM
Automatic and Manual controller mode and it's PID form Pandiani LIVE PLC Questions And Answers 11 September 10th, 2006 07:29 PM
modicon quantum controller srik LIVE PLC Questions And Answers 2 August 18th, 2006 10:51 AM
