This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: Nov 2007
Host link unit lk201
Hi Guys,
I've a problem to connect my C200H CPU01 (host link unit lk201). I've a cable DB9 to DB25 wired like Omron Specs: PC PLC 2------2 3------3 5------7 7-| |-4 8-| |-5 I've set dips switch like Omron sheet I'm using CX-Programmer, I've entered my plc on it but when I'm trying to connect, the RCV led on the host link flash and it fail. Thanks to help me |
#2 |
Have you tried this one...this is the one that I make and everyone likes it
![]() http://www.plctrainer.net/Omron_Universal_Cable.jpg
__________________
www.PLCTrainer.net PLC Trainers, Communication Cables and Automation Supplies, Allen Bradley ~ Siemens ... YouTube PLC help videos.. http://www.ind-concepts.com/Support_and_Downloads.htm |
#3 |
![]() Join Date: Feb 2008
What is the software you have to communicate?
#4 |
I know nothing... about Omron but I did find this at http://forums.mrplc.com/index.php?download=750 (not sure if you had it or not) its there different cables, but your cable may not be your issue...
__________________
#5 |
fons04,
have you tried the following - 1)Link Selector (at back of LK201 ) in ON position 2)SW4 (Command Level) in position 2 3)Baud rate in your software same as per SW3 of LK201 4)Match LK201 unit number with that in software (default - 0) Omron default comm settings are 7 data bits, 2 stop bits, even parity, 9600 baudrate. Hope this helps SVN |
#6 |
I'm using CX Programmer
#7 |
SVN,
I've tried your tips and it make the same thing. I've a LK-201, it exist LK-201-V1, what's the difference and could be the problem? |
#8 |
fons04,
I think the -V1 should not be a problem. If the RCV LED lights but XMT doesn't, it means that the comm settings are not matching (assuming cable is correct as mentioned by you). I think if you post the snapshots of comm settings in CX-Programmer and positions of all the switches (front and back) of LK201-V1 then it will be easier to find out the problem. SVN |
#9 |
I, on the host link LK201:
the RCV not light,it flash when i tried to connect, the RUN does'nt light, the XMT not, the ERROR not. SW1=0 SW2=0 SW3=5 SW4=2 The dips switchs at back are: 1=off 2=off 3=on 4=off and 0V at vertical one Setting: #card host link= 0 Port COM1 9600 7 Even parity bit stop 2 response delay 2 thanks |
#10 |
fons4, for Host Link Unit to work , the RUN LED should be ON.
Check the following for "RUN Indicator does not light" from the section 5-4 of W143-E1-6 (Host Link Units System Manual) If you don't have the manual then you can download it from Omron USA site. Possible Causes: 1) Faulty contact in the connector between the PLC and the Host Link Unit. 2) PLC is resetting the Host Link Unit. 3) Host Link Unit is defective. Remedies: 1) Check and repair connections.Turn the PLC OFF, then ON. 2) If necessary, check the PLC for an error or abnormal reset. 3) Replace the Host Link Unit. SVN
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Omron #3G2C7-LK201-EV1, Host Link Unit | rlmuirhead | LIVE PLC Questions And Answers | 17 | January 12th, 2007 01:11 PM |
| about omron plc host link command : MB | machelec | LIVE PLC Questions And Answers | 7 | July 8th, 2005 11:40 AM |
| Host link | thanhnhan2811 | LIVE PLC Questions And Answers | 2 | April 13th, 2005 07:26 AM |
| Omron Host Link & Cimplicity | rmor | LIVE PLC Questions And Answers | 1 | February 4th, 2005 11:32 PM |
| omron c40k host link | ready961 | LIVE PLC Questions And Answers | 1 | January 23rd, 2003 09:38 AM |
