plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 7th, 2008, 09:25 AM   #1
95z28
United States
95z28 is offline
Old Cutler hammer Plc's
My new company has some old Cutler Hammer PLCs in use. More specifically numerous D50's and a couple of D300's. Upgrading is on the horizon but for the moment one particular D300 is becoming a royal pain.
The biggest concern I have right now is a major failure. I can get a used CPU but lack the C/H software. I had "winGPC v2.50" on my laptop but it was corrupted and unusable.
So my questions are....
Is winGPC available anywhere ?
Is any other software compatible with the D50/300 ?
Thanks in advance
Old February 7th, 2008, 01:32 PM   #2
BTalbot
United States
BTalbot is offline
BTalbot's Avatar
I think these were brand labeled Toshiba units, try a search for Toshiba plc's
Old February 7th, 2008, 10:01 PM   #3
95z28
United States
95z28 is offline
Thanks for the reply.......no luck going that route. I did find a site with winGPC available. I am a bit unsure of compatibility as the software is now a Rockwell Samsung not CH. I will try tomorrow.....
Heres the site if anyone is interested
http://www.atcontrol.com.pl/?a=C
Old February 10th, 2008, 09:12 AM   #4
95z28
United States
95z28 is offline
Talking
A big Thank You to one of the members for sharing his WinGPC 2.11
Old November 18th, 2008, 11:43 PM   #5
psychosunshine
United States
psychosunshine is offline
Converting OLD DOS GPC5 program to WinGPC
I managed to download the program from a D300 with WinGPC, but it does not have the comments in it.
And, I have a copy of the program that was saved with the old DOS GPC program. I think it is GPC5, but not really sure.
Does anyone know how I would convert this old DOS version to the new version or get the comments out of it?
Thanks,
Dave
Old November 19th, 2008, 08:49 AM   #6
jrwb4gbm
United States
jrwb4gbm is offline
Try zipping the file and attaching it to a post here. I'm pretty sure I can convert it to a pdf file where you can read the comments. Also what is the file extension on the old DOS file and on the new downloaded file? Depending on your version of WinGPC there may be a Project Upgrade option under the main "Project" drop down.
Old November 19th, 2008, 11:00 AM   #7
psychosunshine
United States
The advice above worked perfectly. I am using WinGPC 2.51 and the Project Upgrade option exists in the Project drop down menu.
The extension of the original program was .PLC
WinGPC converted it to a new filename with an extention of .LDR
Thanks for the help....
Old December 11th, 2008, 12:49 PM   #8
aguena
Brazil
aguena is offline
WinGPC upgrade is safe?
Hi all,
That is my first post here. I will have to make a very small change in a very large and complex program that is running flawless in an old Cutler Hammer D32LT. The problem is that the program was developed with WinGPC 2.51 software that does not install in our new computers that are now Windows Vista - Brazilian portuguese version (a friend of mine succeed in installing WinGPC 2.51 but only in english version of Vista).
I managed to install WinGPC 3.80 in my computer, but before trying it, I would like to know if that version is fully compatible with program made in 2.51 version. It will be terrible if I have to check or rewrite all the program because changes introduced by the conversion for newer version.
Thanks for any help.
Old August 19th, 2009, 03:30 AM   #9
dmardinly
Greece
dmardinly is offline
Please any one to help me to get the wingpc for D50 old cutler types , I am in urgent need for this softwar ?
Old July 6th, 2010, 05:17 AM   #10
more control
United Kingdom
more control is offline
dm100 programming
Quote:
i know this was an old link but can anybody send me or tell me where I can down load the WinGPC 2.11 software. I need to up load from an old DM100 and have the conection module but no software and cable.
Old July 6th, 2010, 07:01 AM   #11
psychosunshine
United States
WinGPC
I posted WinGPC 2.51 here: http://www.foxautomation.com/wingpc/
I also included some PDF manuals and pinouts.
I hope this helps.
Old July 6th, 2010, 08:21 AM   #12
more control
United Kingdom
I hope this helps.
thank you for this I dont surpose you have any software for the older d100 do you? I m trying to upload an old program and not having much luck with obtaining the software. I have down loaded the ex20 and ex40 software but cant get them to run. I am going to try and old dos laptop at home later.
Thanks again
Old July 6th, 2010, 08:43 AM   #13
psychosunshine
United States
I think this software works with the older D100. The same as the DOS version of GPC
Old July 6th, 2010, 08:47 AM   #14
more control
United Kingdom
when i have instlled the program i can find no refrence to d100 in the list of plc's only d50,d32lt,d300,d320. Do you have a old dos copy and key for it?
Old July 6th, 2010, 09:01 AM   #15
psychosunshine
United States
Try this link: http://xtronics.com/toshiba/cutlerxref.htm
http://www.toshiba.com/ind/data/tag_...tware_2065.ZIP
It looks like you have to use some old Toshiba DOS software.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Cutler Hammer Programming Software Doug_Adam LIVE PLC Questions And Answers 11 June 3rd, 2009 06:22 PM
Cutler Hammer QCPort & S811 SS curlyandshemp LIVE PLC Questions And Answers 0 January 18th, 2008 02:28 PM
Cutler Hammer D100 PLC Keldog LIVE PLC Questions And Answers 1 November 17th, 2006 08:45 AM
Cutler Hammer Panelmate 3000 CONTROLTESTGUY LIVE PLC Questions And Answers 4 April 3rd, 2006 01:01 PM
Cutler Hammer Part? Greg Dake LIVE PLC Questions And Answers 7 November 1st, 2005 07:52 AM
