plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 29th, 2008, 03:56 AM   #1
uptown47
United Kingdom
uptown47 is offline
Memory Reset not working Siemens PLC
Hi all,
Correct me if I'm wrong but if I hold down the MRES switch on a Siemens 300 series PLC and wait until the amber light stops flashing, then release the switch and hold it down again quickly (causing the amber light to blink rapidly) then this should reset the memory?
This doesn't seem to be working on two different 313C PLC's. I do an "overall reset" but when I interrogate the PLC the program blocks (eg. FC1, FC2 etc) are still in there?
Does the overall reset not clear these out or are they held somewhere that's not being erased?
How do I quickly erase these blocks?
Many thanks
Old February 29th, 2008, 04:03 AM   #2
Bratt
Sweden
Bratt is offline
The memory reset does not clear blocks that are located on the MMC card. It only clears the plc and the blocks are then loaded back to plc. If you have a Siemens FieldPG or an external Siemens prommer you can erase the card offline in Step 7. Another way is to use image files and tools from this site then you can use any card reader. Search for MMC on this forum and you will get more help.
Old February 29th, 2008, 04:05 AM   #3
uptown47
United Kingdom
uptown47 is offline
How do I clear the MMC then?
Can that be done through the MRES switch or is there a menu command through Simatic Manager?
Old February 29th, 2008, 04:08 AM   #4
Bratt
Sweden
Bratt is offline
You can go online in step 7 and select the blocks you want to delete but not all attributes are deleted this way. To delete all the only way is an external reader.
Old February 29th, 2008, 07:32 AM   #5
JohnW
England
JohnW is offline
You can clear all data from an MMC card like this:
Instructions:
It is not possible for users to format an MMC. All you can do is "reset" an MMC, which deletes all user data. Proceed as follows.
  1. The MMC is slotted in the bay of the CPU. Your CPU requests an overall reset (slow blinking of the STOP LED).
  2. Set the switch to MRES and hold it there (approx. 9 seconds) until the STOP LED lights continuously.
  3. Within the next 3 seconds you must let the switch go and set it again to MRES. The STOP LED now blinks during the delete procedure.
If the MMC continues to request an overall reset after the procedure described above, then it is defective. Note:
It is only possible to reset the MMC if it contains data that is invalid for the CPU. Otherwise the MMC is only initialized by the procedure described.
Old February 29th, 2008, 07:50 AM   #6
Bratt
Sweden
Bratt is offline
Quote:
Originally Posted by JohnW
Note:
But then you need to put your mmc in another diffrent cpu or? Do you know if this procedure deletes the Saftey attribute for F-Cpus aswell?
Old February 29th, 2008, 07:53 AM   #7
uptown47
United Kingdom
uptown47 is offline
That would confirm my experiments... 2 PLC's, if I swap the MMC's then they request a reset (ie. blink the amber light). When I do the reset it clears the MMC completely.
However, doing a reset to an MMC that has the correct PLC info on doesn't clear any of the blocks..
So, it seems the only way to clear an MMC is to do it online via Simatic Manager.
Thanks for all your help. Much appreciated.
Old October 20th, 2009, 09:18 AM   #8
budahab
Libya
budahab is offline
budahab's Avatar
my s7 313c is stop led flashing evry time and i there is no connection between the plc and pc is the diffrent version is effecting and i made rest memory by mrs and main but is not going well flashing stop led
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Communicate MultiPanel (siemens) Modicon PLC juanmdx LIVE PLC Questions And Answers 5 September 10th, 2007 10:20 AM
Transfer Data From Siemens PLC to AB PLC Danocane LIVE PLC Questions And Answers 8 September 7th, 2007 06:29 AM
memory cards in Siemens PLCs orense LIVE PLC Questions And Answers 2 July 8th, 2007 04:17 AM
Downloading change to S7 PLC in memory card Pandiani LIVE PLC Questions And Answers 8 September 8th, 2006 09:23 AM
addressing of siemens PLC ravikumar LIVE PLC Questions And Answers 4 March 7th, 2006 05:57 AM
