This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
If you're really looking to learn about PLCs, you NEED our book... "Your Personal PLC Tutor - A Guide to Understanding PLCs" Easy to read and uses 'plain' language!
Thread Tools | Display Modes |
#1 |
Free AB SLC and Micrologix Software Utilities Major Release 2
A new version of the Allen Bradley utilities has been posted. This version contains bug fixes and many new features:
- Program Upload/Download - Read All Data and Save to File, then Write Data Back to PLC from File - Support for ML1100, ML1200, ML1500 - Graphing of data It can be downloaded from here: https://sourceforge.net/project/show...roup_id=192333 I need as much feedback as possible. This is a Beta version, so I do NOT recommend testing on a production system initially. Source code will be posted in a few days. |
#2 |
![]() Join Date: Jan 2006
I will test this out this week!! This will make life easy! You rock! |
#3 |
Archie -
When I try to use the "List Data Tables" button I get the following error: "Failed to get program directory size - illegal command or format, Address may not exist or not enough elements in the file" I'm assuming I need to list the data table before I can save that to a text file? I'm using a Micrologix 1500 series C I am able to connect and "Read Multiple Elements", I have not tried to write or read single elements. |
#4 | |
Quote:
This can be a tough one to figure out. I'm actually surprised because most of the testing was done by someone with an ML1500. Can you do a data capture using this utility: http://www.download.com/Free-Serial-...=dl&tag=button Set it up for Serial Port Monitor and Request View. Then run the program and try to list the tables or save the data. Once it captures the data, copy the last request and answer data. That will give me more details of why it failed. |
#5 | |
Quote:
#6 |
I posted the new version with the fix for the LRP processor.
https://sourceforge.net/project/show...roup_id=192333 |
#7 |
I will give it a try today!
#8 |
Archine -
Success! I'll be comparing what your program read/wrote to the plc with my plc program to verify values are all correct, initial results look very good! I appreciate your effort! |
#9 | |
Quote:
#10 |
For anyone interested, the source code is now posted which includes the DF1 driver component used in the Utilities application.
#11 |
Is that the source for Beta2 with the fix for the LRP processor?
__________________
True craftsmanship is only one more power tool away. |
#12 | |
Quote:
#13 |
![]() Join Date: Sep 2008
Thank you for the information and web location.
bitwise |
#14 |
![]() Join Date: Oct 2007
This is amazing and saved me lots of time! If I were doing this for work I'd convince my boss to send a little money your way.
__________________
Build a man a fire, and he will be warm for a day. Set a man on fire, and he will be warm for the rest of his life. |
#15 |
Crud, got caught up in an old thread.
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Rockwell Allen Bradley Programming Software, RSLogix 5, RSLogix 500, RS Linx, RSLogix | vvcd | LIVE PLC Questions And Answers | 21 | September 24th, 2009 10:04 PM |
| Free AB SLC and Micrologix Software Utilies | Archie | LIVE PLC Questions And Answers | 21 | July 9th, 2007 09:47 AM |
| New MicroLogix 1500 vs Existing SLC 5/04 + 1747-SN + Flex IO | wildswing | LIVE PLC Questions And Answers | 17 | September 27th, 2006 01:06 PM |
| SLC to Micrologix comms issues | oafcjimbob | LIVE PLC Questions And Answers | 12 | March 19th, 2006 09:43 AM |
| AB Micrologix Fault Trapping | RMcGhee | LIVE PLC Questions And Answers | 3 | September 6th, 2005 08:51 AM |
