Micrologix 1200 power up
plcguy1
Mar 2008
kitchener
i have a micrologix 1200-L40BWA. im trying to power it up. According to my research. The VAC L1 is connected to the Hot(black) wire. VAC Neut is connected to the Neutral(White) wire. and the ground symbol. is connected to the ground (green) wire. this should give power to the plc right?. if any one could provide any input that would be great. I don't want to burn the sucker out.
Thanks.
Put down the PLC and walk away before you kill yourself.
But since I suspect that is unlikely you will walk away I suggest you read the manual. If you don't have a manual you can download one from the literature library at Allen Bradley's website, www.ab.com.
Pictures;
i wont be touching anything until i know for sure what i'm doing. what i'm trying to do is figure out how to wire the plc so i can get it up and running. and upload some programs. I'm not sure what you mean by what inputs do i want. im in high school so im fairly new at this.
Your original question asked us to provide inputs.
In all seriousness, you should get someone more qualified to do the wiring for you. Then you can attempt to do some downloads.
How did you come to be in posession of this PLC? Is this for a class? If so then let the instructor handle the powering up part.
Do you have RSLogix500 software and RSLinx software? You won't be able to communicate with or program the PLC without it.
I have a microligix 1200 processor for some valve control Im trying to stop it from powering up the outputs that were on prior to power failure...
4,441
Hi I have a 1762-L40BWAR that I use for my central heating. I had a wiring fault which shorted my 24vdc input supply and now wont go, no lights or...
2,462
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
632
I have a MicroLogix 1200 that has an 8 input and a 16 output. Every 6 months-year I get a fault and when online go to error it is something like...
504
Have a bad output on a Micrologix 1200. Moved wire over to an available output, changed program to associate with new output. downloaded program...
751
