plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old March 13th, 2008, 07:33 PM   #1
STL???
United Kingdom
STL??? is offline
Redlion G3 Popup Menu
Hi, is there anyway i can create a Popup next to the panel keys i.e Left side of the screen (like a windows start menu) to describe the panel keys?
I have tried to create one using the following code:
if (Show_Menu)
ShowPopup(Menu);
Show_Menu is an internal bit triggered momentarily by a push button.
Menu is the popup page
I then get a Guru Meditation Code: 02-2007-4918-604
secondly on a Message box in the centre of the screen, i've noticed that if the trigger is held on whilst the message box is active, then no tags are wrote when pressing buttons, i have fixed this using a "one shot" pulse to trigger, this works but if the exit button is pressed triggering Hidepopup() then the popup is gone before a decision button is pressed.
Old March 13th, 2008, 07:43 PM   #2
TWControls
United States
TWControls is offline
TWControls's Avatar
Personally I hate Windows popups but...
if (Show_Menu = true) {
ShowPopup(Menu);
else {
__________________
"It's a lot easier to find another job than to find another family. And families tend to be a lot more loyal than corporations." - Steve Bailey
THE AUTOMATION STORE - Your source for automation supplies, repairs, and PLC training classes
Old March 13th, 2008, 07:56 PM   #3
STL???
United Kingdom
STL??? is offline
The triggering code works fine with popups, I was wondering if it was possible to trigger a Popup on the Left hand side of the screen instead of central, that way you have a guide for each button.
When triggered via button, the screen bombs and gives me the Guru code.
Old March 13th, 2008, 08:07 PM   #4
Brijm
United States
Brijm is offline
Brijm's Avatar
if (Show_Menu)
ShowPopup(Menu);
I haven't found a way to do this through a program/expression, but you can use the action menu of a box or libraray primitive, set to "GoTo Page" Under the target page list box is a show as list box. Select "Popup Menu" and this will create a popup, on the left side of the screen the height of the screen and the width of the contents of the page. You can also do this via the softkeys (menu and such).
Also under the page properties, you can select the popup location.... (Bottom, Left). I haven't used this on an actual screen, and it doesn't seem to work in the emulator.
-brian
Old March 13th, 2008, 08:12 PM   #5
STL???
United Kingdom
STL??? is offline
Thanks - ill give it a try.
Old March 13th, 2008, 08:29 PM   #6
STL???
United Kingdom
STL??? is offline
Gave it a try with show as Popup menu and popup window, still crashes and gives the same Guru message - bummer.
Old March 13th, 2008, 08:32 PM   #7
STL???
United Kingdom
STL??? is offline
Messed about with the size abit and it appears to be working?
Old March 13th, 2008, 08:50 PM   #8
STL???
United Kingdom
STL??? is offline
all working now - i deleted a shadow i had the text written in and just changed the background colour to match and it works a treat.
thanks for your help Brijm
Old March 13th, 2008, 09:26 PM   #9
STL???
United Kingdom
STL??? is offline
OK - next problem!
I have 4 screens configured currently, each screen has the keys assigned to goto page for the other screens, the popup menu also has these keys assigned on its screen also, however when the popup menu is visable - the panel keys do nothing, hide it and i can navigate as normal?
what i'm i doing wrong?
Old March 14th, 2008, 06:24 AM   #10
DanYost
United States
DanYost is offline
DanYost's Avatar
First, if you want to use programming, instead of just a button to show the menu, you can use the ShowMenu() function.
When configuring a page that will be used as a pop-up menu, do not program the softkeys on that page. Add push buttons next to the softkeys. When the page is shown as a menu, the softkey next to the touch screen button will take the action of the button.
Regards,
Dan
__________________
-Dan Yost
Interface and Control Team Technical Support
Red Lion Controls
Check out our new software at www.crimson3.com
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
RedLion G308 to Siemens S5 943 115 series processor 504bloke LIVE PLC Questions And Answers 9 August 2nd, 2011 02:31 AM
Redlion G3: Upgrade to a larger size billysmithde2 LIVE PLC Questions And Answers 17 May 1st, 2008 11:02 PM
G3 and ModBus Brijm LIVE PLC Questions And Answers 12 February 4th, 2008 05:50 PM
RSView 32: Cannot Replace Popup gareth.cantrill LIVE PLC Questions And Answers 2 February 24th, 2006 10:33 AM
MEDOC For Mitsubishi adkeys2 LIVE PLC Questions And Answers 22 December 4th, 2003 03:21 PM
