Difference between profibus FMS and DP
Profibus is the medium.
DP stands for Decentralized Peripherie, meanin this is used to get and ssend info to the outside world by means of sensors and actuators. In other words: your input and output cards are not located in the PLC-rack but remotely. This is used to simplify cabling, because only a 2-wire cable is needed instead of N wires depending on the nuber of ins and outs.
FMS means Field Messaging System and is used for inter-PLC communication. It therefor has nothing to do with inputs and outputs directly, but everything with internal data from the processor.
I believe there even is a third version of Profibus, namely PA or Plant Automation. This is somewhat less used, because it's used for communication between PLC's and computers. The size of data being transported is bigger than with FMS.
Kind regards,
Hi there,
Thanks for the explanation it was more then usefull.
Jean-Pierre,
I geloof dat uw vakantie nu begint, nog een goed verlof.
Rudi frederix
Profibus PA
Hello Jean-Pierre:
Your description of DP and FMS is basically correct:
DP is RS-485 based, master-slave cyclic protocol;
FMS is RS-485 based, master-master acyclic protocol.
However, Profibus PA is a sub-net of Profibus-DP, used to communicate with field process transmitters (level, pressure, temperature) and Ex-zones. Basically it is a digital version of HART communications.
Hope this helps,
Daniel Chartier
Hi all, The questions in the title really. I've been looking at a problem on a profi network. There is a DP/DP Coupler with 'consistent' data in...
6,209
Hello, I have a problem with AO- and AA-Tags. When I use for example the tag AO_Test with the address 200 and type the value 1,2 in, the AA-Tag...
1,386
As per the title. This might seem like a basic question to many, but I'm unclear about the difference between a coil ( ) and an application...
28
3,931
Good Morning , I have 2 Frequency Drive panels to build and commission . It is for 2 pump systems . Just wondering , what is the...
1,940
