plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old May 30th, 2008, 04:52 PM   #1
bbopn
United States
bbopn is offline
bbopn's Avatar
Question Determining what is using the Serial Port
About a month ago I was at a customer's jobsite and used Mdbus Modbus simulator while troubleshooting some DCS problems. I connected to the ProSoft Modbus Card via my Latitude D830 serial port (COM1) without issue and even connected to a Woodward Governer and 489 Multilin... all via the COM1 port.
Earlier this week a co-worker wanted to do some Modbus simulation and asked if I would set up my computer to be a Slave and he would set his up to be the Master. When I tried turning the Mdbus simulator "On", it gave me a message that said it couldn't open the comm port.
I then ran RSLinx opened my drivers and attempted to start the DF1 driver. It gave me a message similar to what Mdbus and the DF1 status had a "Port Conflict" on it.
I realized then that something had grabbed control of my COM1 port and attempted several things like turning services OFF, uninstalling some programs I had loaded up since the last time the COM1 port worked. This did not yield anything.
I then went into my BIOS and changed the comm port to COM2 and the on board comm port is now working.
My question is this.... Is there any program that can help you determine what is taking control of the serial comm port? I did a cursory Google search and didn't come up with much. AB's knowledge base wasn't much help either. It said to close the application that was using the comm port.... which I would do IF I knew what application was using it.
Any direction on this would be greatly appreciated. Even though I have my serial port back by reassigning it to COM2, I feel like this is a cheesy fix and would like to determine what is taking control of the comm port.
Thanks,
Bobby
__________________
Times and technology have changed so much. i remember my first laptop... an etch-a-sketch...
Old May 30th, 2008, 05:55 PM   #2
danw
United States
danw is offline
danw's Avatar
I have searched in vain for the utility that would report what has taken possession of the COM port without success. If you discover such a thing, would you be sure to tell us?
The only thing I can think of is to take a screen shot of task manager (for a record of the list or running apps), then do the laborious task of figuring out which running app could grab the serial port. If you're like me, you won't know what most of them do, so it'll be the Google-the-executable-file-name-effort to see what comes up.
Dan
Old May 30th, 2008, 06:26 PM   #3
gmferg
United States
gmferg is offline
gmferg's Avatar
I've had a similar thing happen to me on occassion. After trial and eror, I discovered my culprit was RSLinxNG.exe. Pull up task manager and click over to Processes tab and find RSLinxNG.exe and end the process. COM1 is now free.
I think RSLinxNG.exe is used for RSLinx Enterprise as I don't see it come up until I launched RSView Studio.
This isn't the fix you were looking for but, it's another thing people can look for when their COM1 is locked up.
Old May 30th, 2008, 06:47 PM   #4
Ken Roach
United States
Ken Roach is offline
Ken Roach's Avatar
I'm not aware of something that specifically looks at the COMx port and tells you which service or process is using it.
What I do is use the SysInternals "Process Explorer" (now owned by Microsoft).
http://technet.microsoft.com/en-us/s.../bb896653.aspx
In Process Explorer, select "Find Handle or DLL" and search for the word "serial". This should show anything that is using your serial ports.
Even if the process doesn't have a name, it will have a Process ID number (PID). You can go into the Windows Task Manager (via Ctrl-Alt-Del) and select View -> Select Columns to enable viewing the Process ID numbers, which can lead you to the image name of the program that's using your serial port.
It's a long way around, but it lets you get under the hood of the Windows COMx interface and peek around.
__________________
"Intelligence is the capacity to know what we are doing and instinct is just instinct. The results are about the same."
Old May 30th, 2008, 07:06 PM   #5
panic mode
Canada
panic mode is offline
panic mode's Avatar
what was the software that had last successful connection?
that is probably your culprit...
ActiveSync etc. is also to be watched. the last time i used it, this was not the most cooperative thing to stop or remove.
Old May 30th, 2008, 10:24 PM   #6
danw
United States
danw is offline
danw's Avatar
Ken,
Thanks for that great link and explanation of Process Explorer.
You get a star for that effort!
Old May 30th, 2008, 10:46 PM   #7
bbopn
United States
bbopn is offline
bbopn's Avatar
Ken... Thanks for some good tips.
I wonder how hard it would be to come up with something like this. The only problem is the Serial Ports are almost like the dinosaur
I loaded up Process Explorer, but I didn't get a hit on "serial" during the search. I then searhed "COM" and had a bunch of hits for COM3. Things that make me go hmmmmm.
I guess for now, I'll leave it defined as COM2 and keep trying to dive a little deeper as time permits.
Thanks again to everyone that answered.
==Bobby
__________________
Old May 31st, 2008, 04:32 AM   #8
pouch
United Kingdom
pouch is offline
Port Monitoring.
Try the following link, this will take you to other Microsoft utilities one of which is a Port monitoring utility.
http://technet.microsoft.com/en-us/s...84cb9e2f5.aspx
Regards
Paul.
Old May 31st, 2008, 05:39 AM   #9
OZEE
United States
OZEE is offline
What I usually do when I have problems with a COM port is to just go to Device Manager and delete the port, then reinstall it. It's a pain, but it works every time.
Old June 3rd, 2008, 02:09 PM   #10
SNK
Canada
SNK is offline
SNK's Avatar
I am struggling with the same problem
I too, have a Dell D620, that my Com1 port has been taken hostage now for quite sometime. Every re-boot, it captures the Com1 port again, and nothing else can access it.
I have tried process-explorer, numberous other applications, with no such luck. Nothing indicates COM1 useage.
The only way that I can get the COM1 back again is by uninstalling, and reinstalling in DeviceManager, and trust me, it is a royal pain in the ARSE, every time that you need it.
(I am using Win2K, SP4)
Other laptops in my group do not have this issue, but I have some more software installed.
I have uninstalled as much as possible, in an attempt to find out what is causing the problem.
The one thing that sticks in my head is that I tried a piece of software that someone posted here,
http://www.plctalk.net/qanda/showthr...ight=pocket+PC
I seem to remember my issues started after that....it could be a coincidence, but that is what I remember.
I am fed up changing my com ports before I connect to anything serially.
Does anyone have an update as to a fix?
I am going to try installing the above software on another laptop, and see if I can duplicate the issue...
Old June 3rd, 2008, 02:14 PM   #11
Mickey
United States
Mickey is offline
Mickey's Avatar
[quote=SNK
I am going to try installing the above software on another laptop, and see if I can duplicate the issue...[/QUOTE]
Make sure its the boss's laptop.
__________________
Mickey
If you want happiness for an hour-take a nap. If you want happiness for a day-go fishing. If you want happiness for a month-getmarried. If you want happiness for a year-inherit a fortune. If you want happiness for a lifetime-help someone else.
----- Chinese Proverb
Old June 3rd, 2008, 02:18 PM   #12
John M
Canada
John M is offline
John M's Avatar
I don't know if this will help but PortMon (available here)
http://www.download.com/Portmon/3000...-10630852.html
shows me what Process is using all of my ports that it is supposed to monitor.
Old June 3rd, 2008, 06:20 PM   #13
SNK
Canada
SNK is offline
SNK's Avatar
John,tried that. Thanks for the info though.
That specific software is not that easy to figure out.
I tried some others that shows up all UDT,TCP/IP ports that are open, and indicates the process as well. But, it seems to be more ethernet related, and that it doesn't seem to be hardware serial ports. It shows about 12 services running on my corporate network, its IP addresses and such, but does not mention COM1 ports. (or any serial port that I can identify)
As I said, I have installed about 10 pieces of software today with no luck.
I am really thinking about reverting back to an older image that I knew worked. And then test in tiny increments.
Old September 20th, 2011, 06:31 PM   #14
rmceachran
Canada
rmceachran is offline
Hopefully I can get this thread going again because I am about to put my computer through a wall:
I have tried just about everything mentioned in this thread and more . It definitly seems like my com port is being taking over by something.
Strangely enough I keep thinking it is something to do with Rslinx Classis / Rslinx Enterprise
I have most of the latest and greatest software being:>
RsLinx Classic Professional 2.58.00.15
Factory Talk View Studio 6.0 (with no DF1 driver configured under Factory Talk view )
The cable I am using is 1761-cbl-pm02, serc
and I can not connect using my Rs-232 DF1 Device
I have changed com ports in BIOS I have closed RslinxNG processes.
I have used portmon and didnt quite understand the info I was seeing except for saying communication failed.
Here is a sample of what portmon displayed.
Rate: 1200
StopBits:1 Parity: EVEN Wordlength:8
EOF:0 ERR:0 BRK:0 EVT:0 XON:11 XOFF:13
Shake:1 Replace:40 Xonlimit:2048 Xofflimit:512
RI:-1 RM:0 RC:0 WM:0 WC:0
Purge:TXABORT RX ABORT TXCLEAR RXCLEAR
Mask: RXCHAR BRK ERR
Length 4
Mask: RXCHAR BRLK ERR
If any one has ANY insight at all I am willing to try anything.
Old September 20th, 2011, 08:43 PM   #15
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
Rate: 1200
Length 4
I believe that RSLinx Enterprise and RSLinx Classic can get into a battle over the serial port and everybody loses.
I don't have the latest technotes with "RSLinx Enterprise" and what to look for but I think a search based on that quoted text here and at ab.com should help
__________________
A rebel who's taking a pause.
It's not all the variables I am most concerned with, it's the undiscovered constants.
"You can lead a horse to water but if he's got his head up his as$ he may die of thirst anyway."
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Cellular Modem to SLC 504 via serial port RKaighen LIVE PLC Questions And Answers 0 March 14th, 2008 07:59 AM
PanelBuilder on laptop; serial port question drpepper LIVE PLC Questions And Answers 6 October 15th, 2007 11:54 AM
Ethernet or Serial port AGENTTINFOIL LIVE PLC Questions And Answers 6 January 22nd, 2007 09:22 PM
Compact Logix Serial Port Diagnostics plcnovel LIVE PLC Questions And Answers 0 October 19th, 2006 12:51 PM
Need PLC to control via serial port ... LIVE PLC Questions And Answers 9 February 28th, 2003 07:01 AM
