This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
Lenze and Siemens
Anyone knows something about Lenze ?
I have 8 drives in a certain project. Connected with profibus on an S7-315 CPU. The drives are positioning drives. So, what I send is: the program set that he has to do and the setpoint position and a control word to start the drive. I receive: the actual program set, the actual position and a statusword. My question: is it possible to transfer the actual fault number in soms way, I don't know much about Lenze... |
#2 |
![]() Join Date: Feb 2005
#3 |
Could you be so kind to describe your problem entire?
In other words - Why do you need in an actual faul number? I'm asking because I know a solution, probable ... |
#4 | |
heyhey
Well,
I'm new in the company where I am now. They build a machine in France one year ago. I had a phone call about a Lenze problem. To see what fault they had, I first had to explain how to use the keypad form Lenze. He finally found the buffer paramter and could tell us the faults, this took one day !! I don't want that to happen to the machines that I will program. The fault was P2, there was a limit switch defective. So, what I want for the new lines, is: when a drive goes in fault, the faultnumber (same number as on keypad 3152 for example) has to be shown on an HMI device. I work with Siemens PLC's, Siemens HMI's and Lenze drives. All on profibus. If u want I can tell you some parameters in the Lenze and some codes that I send and receive with the PLC... ...? Quote:
#5 |
Supporting Member
![]() Join Date: Nov 2006
The Lenze drives I've come across are pretty much the same as Siemens when it comes to the Profibus interface. As well as exchanging data via the PZD area, you can also use the PKW area to exchange parameters.
Here's an example I found using Google: http://akb.lenze.de/akb-englisch/res...ample_V1_2.PDF |
#6 | ||
Quote:
Quote:
http://rapidshare.de/files/39646286/...anual.zip.html |
#7 | |
Quote:
__________________
Regards Dave "When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity." Albert Einstein (1879-1955) |
#8 | |
tnx
Thanks a lot,
I'll try this out greetings, gerry Quote:
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Siemens suggested this.... | katratzi | LIVE PLC Questions And Answers | 0 | May 13th, 2008 03:14 PM |
| Lenze 9300 POS and Siemens | Combo | LIVE PLC Questions And Answers | 3 | February 10th, 2008 04:02 AM |
| Lenze 9300 Vector | Vittu | LIVE PLC Questions And Answers | 0 | August 28th, 2007 03:41 PM |
| Lenze Global Drive Control (OSZ) | Combo | LIVE PLC Questions And Answers | 2 | October 13th, 2006 12:46 AM |
| LENZE 8200 invertor problems | Eelco | LIVE PLC Questions And Answers | 2 | November 11th, 2004 08:36 PM |
