This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: Jun 2008
Howto control tag consume interval on 1756-L61?
Hi all,
I'm new to both Rockwell/AB and to my company. I find a quite complex CLX-5561 software here that needs some debugging / improvement. My problem is: - I have a CLX based machine with ethernet interface to a PC. - At PC side, some tags are consumed - but I don't see how frequently. - I'd like to set an "update interval" of -say- 5 secs. Means: I'd like the CLX to update the data the PC is consuming every 5 secs. Now the question is: Where would I have to look for parameters controlling this - at CLX side, or rather at PC side? And what symbol names should I look for? Is there any documentation explaining how to deal with it? I searched through this website and found some hints like "goto AB website and look for 'common procedures'" - but what I found there did not clarify it to me. Any help appreciated. Thanks. |
#2 |
PC? As in to an HMI? That would be controlled by the I/O scan settings on the OPC server, not the PLC.
PLC "Produced/Consumed" tags aren't on any interval delay, and are most commonly used for inter-PLC communications. |
#3 |
Hi rdrast,
yes, PC as HMI (mostly). Yes, it's clear that Produced/Consumed Tags are not primarily designed for this - but currently I have to live with it :-) I will check your hint to OPC server settings. Thanks very much for the quick reply. |
#4 | |
Quote:
#5 | |
Quote:
__________________
Work to Ride, Then Ride to Work |
#6 |
Hi all,
thanks for your replies. @curlyandshemp: yes, this is the way to configure it if you are communicating between PLCs. But I have a PC (Windows) Program being the consuming side. And - as I have learned today - not using OPC but CIP protocol. They have implemented it in C++, and when looking for "RPI" in the source code, I finally found it. Now I begin to understand how it's working :-) Thanks very much for your help! Regards, oldnewbee |
#7 |
I am very surprised to hear that your PC application is genuinely using Produced/Consumed Tags. I have never seen that implementation used on an HMI or database connectivity application. Even RA uses ordinary explicit messaging for their FactoryTalk data server.
Can you tell us what company wrote the PC side ? Are they an ODVA member ? |
#8 | |
Hi Eddie,
Quote:
Excuse me please, I cannot go into details too deep, but as far as I understand / guess it up to now, this software has grown more or less like this: - 15 years ago there was need to have a PLC controlling a certain type of process-oriented machines. - They choosed Rockwell (or AB, at those times?) - for whatever reason. - Very early it was desirable to have a PC based HMI visualizing process data over time. - Since I find some basic concepts of CLX software (devices, subscriptions, ...) also in the HMI software, it seems to me that the HMI was originally designed more or less to fit the software / process / communication structure given by Rockwell / AB resp. - May be this all started at times when there were no external products available solving the needs. - So, yes, we have this kind of application that surprised you. But since I'm new to CLX programming, I don't know which alternatives are available today, i.e. how / with what means one would implement an HMI for CLX today. Btw, I actually don't know what "ordinary explicit messaging" means in detail, so I cannot judge the differences :-) (Up to now I have mainly done C and C++ programming.) Hope this gives you a clue about my situation. Regards, oldnewbee |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| How Do I get Control Logix Consumed Tag Status | sikoraj | LIVE PLC Questions And Answers | 3 | January 8th, 2008 05:45 PM |
| Retain Controller Data in an HMI tag (Allen-Bradley) | Money4Nothing | LIVE PLC Questions And Answers | 16 | July 19th, 2007 07:38 AM |
