plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old June 20th, 2008, 07:02 AM   #1
manse80
Denmark
manse80 is offline
Pointer CC-Link communication with Festo valve blocks
Hi.
I am trying to connect to 2 Festo CPV valve blocks with a CC-link module(QJ61BT11N).
But I keep on getting an error on the CC-link module.
I have set the baudrate to 10Mb on both the module and the Festo blocks. The addresses are set to 0 for the module and 1 & 2 for the two blocks.
The wireing are connected as described in documentation.
Still I can't get the data linking running.
Can anyone help with the problem?
Old June 20th, 2008, 07:09 AM   #2
panic mode
Canada
panic mode is offline
panic mode's Avatar
chech this and see if it helps:
http://forums.mrplc.com/index.php?dlcategory=17
Old June 20th, 2008, 07:18 AM   #3
manse80
Denmark
manse80 is offline
Configuration seems ok
I have connected to an Mitsubishi DO module and here the communication works perfect. So I belive the basic networks settings are okay.
So I'm down to the Festo blocks.
Old June 20th, 2008, 07:44 AM   #4
panic mode
Canada
panic mode's Avatar
are you using proper slave type for festo block? this is very important. example in link above was using SMC valve block which was different type from basic I/O and it was mapped 3 "stations" instead of one. you will find this info in festo documentation.
Old June 24th, 2008, 01:02 AM   #5
manse80
Denmark
manse80 is offline
Found the error!
The problem was connection of the bus cables.
Festo have written pin names on the cable connector. But two of these names (DA and DB) was switched, and as a result the bus wasen't able to link data.
Bad error - not easy to find.
But thanks for the help and input anyway
Old June 25th, 2008, 06:56 PM   #6
panic mode
Canada
panic mode's Avatar
interesting, i had just recently same problem with some factory made cables (Phoenix Contact, Lapp)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
CC Link thomas1000 LIVE PLC Questions And Answers 8 June 8th, 2006 04:23 PM
To setup parameter for master cc link fengkong LIVE PLC Questions And Answers 1 May 28th, 2006 02:13 AM
CC Link Setup frattonise LIVE PLC Questions And Answers 1 April 21st, 2005 05:35 PM
Profibus to CC Link Guest LIVE PLC Questions And Answers 2 May 6th, 2004 11:13 PM
connecting to festo manifolds with AB RIO oregonsam LIVE PLC Questions And Answers 6 May 19th, 2003 11:19 PM
