plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old June 29th, 2008, 08:56 AM   #1
Contr_Conn
United States
Contr_Conn is offline
Contr_Conn's Avatar
OT: Home HVAC Fan Blower
Way OT, but controls related.
I know I should find HVAC forum for this, but I am sure controls guys may have an idea:
My house central HVAC blower just quit working last night,
Only Fan problem, all other functions "look OK" as far as I can see
AC compressor turns ON, but blower motor makes noise (no spin) for 5-6 seconds and quits for another 40-50 sec shutting down compressor as well. At this point it tries again...
It looks like I will not get anyone for a few days, so I decided to look myself.
I restarted it in Fan ON mode (no AC), it started once and nothing since, same problem.
Whole thing is in the attic and hard to get in.
Visually all looking clean, incoming 120VAC is there.
So I am thinkg that 3 things can be bad:
- Capacitor
- Controller (fan control circuit)
- Motor itself (no belt)
Since it make a noise like it lost a phase, I am thinking just to replace capacitor.
Motor looks like a single phase with huge capacitor on the side and has 3 different leads for 3 different speeds, all connected to controller.
Any other ideas?
Old June 29th, 2008, 09:32 AM   #2
just_lionel
United States
just_lionel is offline
just_lionel's Avatar
I've had to replace the capacitor on mine a couple of times, it was acting just like yours is.
__________________
just_lionel
The sooner you fall behind, the more time you have to catch up.
Old June 29th, 2008, 09:54 AM   #3
Contr_Conn
United States
Contr_Conn's Avatar
Just spoke with one of AC repair guys - he will not be able to come at least intil Tuesday, but gave some BS about motor overheating - I explained to him the it was on for last 12 hours and should at least start for few seconds to get overheated. He did not like me mentioning a capacitor.
Sound like replacing just a capacitor is too small job
Old June 29th, 2008, 10:05 AM   #4
CharlesM
United States
CharlesM is offline
I vote for the cap. I had to change one out a few years back.
Old June 29th, 2008, 10:09 AM   #5
Contr_Conn
United States
Contr_Conn's Avatar
I think I am going to take cap out to see if I can measure it.
May be I can get one without having guy to come
Old June 29th, 2008, 10:40 AM   #6
Contr_Conn
United States
Contr_Conn's Avatar
OK, capacitor is in my hands now,
Measuring capacitance with DMM: 0
Measuring small capacitors I have - all show correct readings
So I can safely say - it is bad!
Now how can I find it on Sunday?
Google search returned many hits,
This is a first one
http://www.alliedelec.com/Search/Pro...=&DESC=97F9002
Old June 29th, 2008, 01:34 PM   #7
keithkyll
United States
keithkyll is offline
Appliance parts. Well stocked hardware store. I assume it's a run cap. Metal, oval, about 5 microfarads (MFD).
If it's round plastic, try to get a metal one. They last longer.
Edit - Looked at Allied link. That one looks good. Carry that picture to hardware/appliance store.
If you have an old AC outdoor unit, it will have one. Don't go lower than 8 MFD.
Old June 29th, 2008, 02:33 PM   #8
Contr_Conn
United States
Contr_Conn's Avatar
This link from Allied is exact part number I have 97F9002 10uF 370VAC rating.
Local part stores closed today.
I will call them tomorrow morning.
If not, then I will order from Allied.
It's not hot today and cold front coming tomorrow, so I can leave few days without AC
Old June 29th, 2008, 02:45 PM   #9
Duane Boston
United States
Duane Boston is offline
WWGraingers
Grainger Part number number 2GE79 is exactly what you are looking for. It will break the bank at six dollars 29 cents. Sounds like a deal to stay cool.
Old June 29th, 2008, 04:02 PM   #10
Contr_Conn
United States
Contr_Conn's Avatar
I see McMaster has it also 7602K27
I have both locally but Grainger is just 5 miles away.
Why home stuff always breaks on weekends or after 10pm weekdays?
Last year I had roof leak at 4 am...
Old June 29th, 2008, 04:26 PM   #11
JeffKiper
United States
JeffKiper is offline
JeffKiper's Avatar
I was HVAC man yeas ago. I only used 4?? volt caps. Sorry I can't remember the exact voltage. This will give you a greater safety factor. It will be several hours before I get to the house but when I get home I will fill in the ?? . You can go up in the voltage not down. The micofarad rated needs to be with 10% of the rated. I had a make a cap that I carried with me on service runs. It was a group of caps that I had to place jumpers between. I was about $75 but a nice troubleshooting tool.
__________________
There should be a minimum IQ before people can breed
Old June 29th, 2008, 05:40 PM   #12
Peter Nachtwey
United States
Peter Nachtwey is offline
Peter Nachtwey's Avatar
Location: Vancouver, WA, UMSA, United Marxist States of America
While were at it. I have a slightly different AC problem.
I just found out my AC died. I usually don't use it unless it get very hot 90+. I have only checked the breaker and the fact the fan fill on the outside unit will not turn the blower is fine but I only get hot air. The unit is 10 or 11 years old. If the compressor motor is burned out should I bother with replacing the motor or is it time for an expensive upgrade? BTW, I have natural gas for heating but I would consider a heat pump because it could be used most of the time. Rarely does the temperature go below freezing for any length of time.
Do the ex HVAC guys have a suggestions? There would be a circuit break inside the AC unit itself would there? I would need to remove the covers.
Old June 29th, 2008, 06:34 PM   #13
JeffKiper
United States
JeffKiper's Avatar
Peter
Is the compressor running when the relay pulls in? Does the relay even pull in? FYI It is more than likely a single pole
__________________
Old June 29th, 2008, 06:40 PM   #14
Contr_Conn
United States
Contr_Conn's Avatar
Peter,
I have separate 2-pole breaker for outside AC unit.
Furnace(gas)including fan blower use own single phase breaker.
I remember having similar problem few years ago when 2-pole breaker tripped for some reason.
Old June 29th, 2008, 06:56 PM   #15
Gil47
New Zealand
Gil47 is offline
Gil47's Avatar
This is a first
A question asked by Peter that I can answer.
If the Compressors motor is burnt out it is time to update, but in saying that is most unlikely to be burnt out, more likely to be a starting relay fault, or starting / run capacitor, or you may have a manually resettable high pressure switch that needs reset.
Its a shame that this is probably the only question from Peter that I may have got right.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
OT: Home project needs hysteresis or mag brake OkiePC LIVE PLC Questions And Answers 2 September 3rd, 2007 05:52 PM
OT: Fan Control Brijm LIVE PLC Questions And Answers 4 August 10th, 2007 07:26 AM
OT Question About Leaking Fan Shaft Seals: Russ LIVE PLC Questions And Answers 2 April 15th, 2007 04:47 PM
A plea for help...and mentor damianjones LIVE PLC Questions And Answers 72 February 7th, 2007 11:10 AM
Delay Timer AGENTTINFOIL LIVE PLC Questions And Answers 9 February 11th, 2006 07:25 PM
