plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old July 2nd, 2008, 12:22 AM   #1
dmbartender
Germany
dmbartender is offline
AB CLX controller communicating with S7
Hello all,
I would like to make a 1756-L62 CLX processor communicate with an S7 CPU 317-DP (coupled to a CP-343 ethernet card). The data to communicate will be a sructure having about 14000 bytes. The data is to be sent from the CLX to S7.
First of all, has anyone connected a CLX and S7 processor together?
What is the largest packet size CLX can send using 'produced' ?
Any tips would be great.
Old July 2nd, 2008, 01:40 AM   #2
dmbartender
Germany
This post is a throwback to thread: http://www.plctalk.net/qanda/showthr...190#post277190I've also read through some older threads concerning communication between S7 and CLX, however the data I need to send is of much larger magnitude.
The SST card from woodhead can write a maximum of 244 bytes to a slave, if I've understood that correctly and the slave would be the S7 controller.
I'd need to send 14000 bytes.
Is there a solution for sending such large amounts of data? OPC server, or Profinet Proxy?
The time isn't so critical.
Old March 24th, 2009, 05:35 PM   #3
cbattles
United States
cbattles is offline
Did you ever find a solution? I have a similar task of communicating from a Siemens S7 to a A-B SLC-5/05.
Old March 25th, 2009, 12:12 AM   #4
dmbartender
Germany
well, first of all, the amount of data to be sent was reduced and sent over separate UDP connections. I ended up using a CP-343 on the S7 side, and EWEB module on the CLX side. On the S7 side it's actually pretty easy using the AG_Send and AG_Recv blocks. It's trickier on the CLX side though, requiring a number of different message commands.
Old March 25th, 2009, 05:24 AM   #5
ss4884
India
ss4884 is offline
Hi dmbartender,
Using CLX u can communicated wit any device via Ethernet using TCP/IP Sockets..
Your Hardware needs a 1756-EWEB module and u can use MSG instruction to transfer Data to any device over Ethernet,
Old March 25th, 2009, 05:48 AM   #6
JesperMP
Denmark
JesperMP is online now
JesperMP's Avatar
How did you do it ?
Quote:
How about a short howto for the steps required to achieve this ?
Post it in the downloads section, and gain eternal fame and praise.
__________________
Jesper
Old March 25th, 2009, 05:54 AM   #7
ss4884
India
ss4884 is offline
Hi JesperMP,
i can get u the details from CLX side but i not sure how far it can work with siemens..
Old March 25th, 2009, 06:05 AM   #8
JesperMP
Denmark
JesperMP's Avatar
I dont have any need right here and now.
But the question has been asked before, so it would be really nice if someone did this once and for all.
__________________
Jesper
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Siemens S5 and S7 Dual Masters for Profibus daveswerld LIVE PLC Questions And Answers 15 December 16th, 2008 02:15 AM
CLX and S7 mrmss LIVE PLC Questions And Answers 6 January 30th, 2006 01:05 PM
Communicating with/programming AB Micrologix 2000 plc micahfrase LIVE PLC Questions And Answers 3 November 8th, 2002 12:20 AM
Communicating GE-FANUC with AB SLC5/04 sherman4 LIVE PLC Questions And Answers 2 July 24th, 2002 05:47 AM
Communicating AB with Johnson Controls Russ LIVE PLC Questions And Answers 3 July 23rd, 2002 01:40 PM
