This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: Jul 2008
S7-200 and analog input problem
Dear everybody
Please guide me about analog input problem in siemens s7-200. I use two type of analog input modules, the spec. of first one is: EM 231 AI 4x 12 Bit 231-0HC32 And the 2’nd one is: EM 231 AI 8x16 Bit 231-0Hf22-0XA0 The first one is operates normal, but the second one dose not do anything. I replaced the 2’nd one instead of 4 input analog module to test but it doesn’t do anything again. I have set the dip-switches as follow: For 4 input analog module: Dip 1 and 3 are on as siemens manual for 0-10V input. For 8 input analog module: Dip 3 and 5 are on as siemens manual for 0-10V input. For more information I have checked the SMB8 and SMB9,they were as SMB8 =12(00001100) and SMB9= 0. I would be pleased if someone write me for more help and guidance. |
#2 |
![]() Join Date: Feb 2005
First obvious question, is the power indicator on the module lit. If not it is either a supply problem or a sensor is shorted to ground.
Bryan |
#3 |
Dear BryanG,
Yes the power indicator is lit. In adition I have checked the sensors and wiring. As I wrote I replaced an other module with 4 inputs instead of 8 inputs module and it works well. |
#4 |
Next step, which you will probably have done is to connect a meter across the 10V input and make sure that there is a signal there and that it is the correct polarity. If that is OK then there are two possibilities:
A faulty Analogue Unit. Siemens haven't made the new 8 input analogue unit backwards compatible with older PLC firmware versions. Either problem will need a call to your local Siemens Technical Support or post a question on the Siemens Forum. Bryan |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Analog s7 200 Em235 | vatersauto | LIVE PLC Questions And Answers | 0 | February 26th, 2008 10:08 AM |
| Strange behaviour of Analog Input Module - Siemens S7-300. | drspanda | LIVE PLC Questions And Answers | 18 | July 24th, 2007 12:51 PM |
| s7 200 plc | m.raji | LIVE PLC Questions And Answers | 2 | February 23rd, 2006 02:10 AM |
| Analog Problem | BoxerBrats | LIVE PLC Questions And Answers | 43 | April 12th, 2005 12:24 PM |
| Set/ Rst Problem In S7 - 200 | reachasp | LIVE PLC Questions And Answers | 1 | January 6th, 2004 01:02 PM |
