plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old September 16th, 2008, 08:13 AM   #1
Zenith63
Ireland
Zenith63 is offline
Help with encoder connected to logic circuit
I know this might not be the right place to ask this but I'm kinda stuck and haven't come across anywhere more likely yet.
Basically what I'm trying to do is time the acceleration of an encoder. I have a PCI card in my Windows PC but it's not a counter card so isn't capable of the timing I need. It has a couple of fast counters and some digital inputs and outputs.
The encoder is a Hengstler RI38 with A,B and Z outputs, these are pushpull type. So 50 times a revolution the encoder sends a pulse on the A line. What I want to do is feed this A input into the CLOCK side of a JK flipflop with the J and K inputs tied. The result being that when the encoder sends its first pulse the output of the JK will be 1 and will stay 1 until the next pulse when it will toggle to 0 and so on.
I've tested my JK flipflop with a slow 555 timer pulse and what I'm looking for works fine, but when I connect in the encoder things start to go a bit mad. Spinning the encoder is causing the flipflop to toggle without me even connecting the encoder to the flipflop, it seems to be coming through ground or +5V. Basically I think I have some sort of noise issue or I have completely misunderstood how to connect the encoder to a TTL circuit. With a probe on the 555 timer I see a LOW signal as 0V and HIGH as about 5V, but from the encoder a LOW seems to be about 0.6V and a high somewhere over 4V.
Does anybody know what I'm doing wrong here? Do I need pull up or pull down resistors? This kind of thing isn't my speciality so I imagine one of you gurus will look at it and wonder why the hell I forgot to connect component X to connection Y .
Any and ALL help much appreciated!
Old October 23rd, 2011, 01:57 AM   #2
a.aladawi
Jordan
a.aladawi is offline
s7 200
Please help;
Old October 23rd, 2011, 02:07 AM   #3
a.aladawi
Jordan
I am programing a roll forming machine, after dividing and subtracting process. it was the zero point in (-675)reading by vd1, tell me please how i can use the vd1.
Old October 23rd, 2011, 09:48 PM   #4
iant
Australia
iant is offline
iant's Avatar
Quote:
HI you need to create a New Thread - This is posted in an existing post
__________________
Give all the answers
- People seldom learn.
Guide People to the posibilities
- Their Answers will come easily.
- Their Knowledge will grow.
They will then teach others
Regards
Ian Trost
Old October 23rd, 2011, 09:51 PM   #5
iant
Australia
iant is offline
iant's Avatar
Quote:
Originally Posted by Zenith63 View Post
Not sure exactly how you have connected this.
do you have a Breadboard with I.C's on it.
The PUSHPULL type encoder needs to know what voltage to switch.
So - Yes you need either Pull Up or Pull Down resistor depending on your logic.
If you have an I.C. Breadboard then get a decade counter Chip
designed specifically to count.
__________________
Regards
Ian Trost
Old October 24th, 2011, 02:21 AM   #6
Zenith63
Ireland
Zenith63 is offline
Thanks iant, I discovered that after a few days messing around. 3 years late with the reply but appreciated!
Old October 24th, 2011, 02:26 AM   #7
iant
Australia
iant is offline
iant's Avatar
Sorry I had seen the other post - sent a msg to him an neglected to realise the date of your post
I was off the site for those three years or I would have helped then
Have a drink on me
__________________
Regards
Ian Trost
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Same "ONESHOT" in Multiple Locations skyfox LIVE PLC Questions And Answers 21 May 28th, 2007 10:33 AM
Encoder SSI double connection Kataeb LIVE PLC Questions And Answers 3 March 6th, 2007 01:42 AM
Absolute encoder or SSI counter Fault ason LIVE PLC Questions And Answers 0 December 20th, 2006 02:44 PM
absolute encoder Vs Sinecosine encoder friendly_encoder LIVE PLC Questions And Answers 5 November 13th, 2003 07:29 AM
encoders and plcs ready961 LIVE PLC Questions And Answers 20 January 23rd, 2003 08:18 AM
