This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
VersaView? PanelView Plus CE?
Greetings, Normally I purchase the standard Panelview Plus line of HMI's from AB. I've also purchased a VersaView in the past. Is the VersaView now what is called the PanelView Plus CE? It looks that way. I need to know if I can install VNC server on a PanelView Plus CE. Is there even a VNC server available for the CE OS? I see there are many VNC viewers on the web for the CE OS, but little or no VNC servers for CE. I want to acess and control the PanelView Plus CE. Has anyone done this? TIA, Greg
#3 |
I already saw that
As I stated, I need the server to run on CE. This says CE is only supported on the viewer.
Greg |
#5 |
Ha, yes, that's the other one I looked at. It's uncompiled and you need Visual C++ to compile it, which I do not have.
I have found a few others on the web which I will test tomorrow. If I have success I will post the link back here for future users. Thanks for your input, Greg |
#6 |
I kind of figured that you had came across that. I just figured that I'd give it a shot since nobody else was posting.
Good luck. |
#7 |
Again, I greatly appreciate your input so far. Have a good night!
Greg |
#8 |
![]() Join Date: Oct 2007
You can always try compiling it with the Express versions of visual studio: http://microsoft.com/express
__________________
Build a man a fire, and he will be warm for a day. Set a man on fire, and he will be warm for the rest of his life. |
#9 |
I got it!
We tried compiling the VNC server CE that was on Sourceforge.net and it didn't work after the compile.
I talked with a Rockwell guy and he said it is on the CD that ships with a VersaView. We dug out the CD and sure enough, it had VNC Server for CE on it! We copied the required files to CF and we installed on the VersaView. It works like a charm. We now have remote access to the Versaview. Thanks, Greg |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Touch screen Panelview plus CE | wilsonzhu | LIVE PLC Questions And Answers | 2 | April 28th, 2008 11:41 AM |
| How To Origanize Three Controlnet Panelview Plus Ce | wilsonzhu | LIVE PLC Questions And Answers | 2 | April 9th, 2008 04:58 PM |
| Running Batch File On VersaView CE | wdm | LIVE PLC Questions And Answers | 0 | November 17th, 2006 10:39 PM |
| ActiveX controls in AB VersaView CE | iknowsomeplc | LIVE PLC Questions And Answers | 0 | December 16th, 2003 10:17 PM |
| AB PanelView Plus / VersaView CE ? | JesperMP | LIVE PLC Questions And Answers | 11 | May 27th, 2003 12:46 PM |
