This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: Nov 2007
Notebook for allen bradley
I am new to the SlC world and my employer wants me to learn PLC programing to use on machinery in the plant. I have already bought Phil Moores books and started to study them . The question I have is what notebook would be best to purchase for Allen Bradley software? What ports do I need? Do I need a floppy drive? Any help will be appreciated.
#2 |
Find out what PLC processors your plant is using. You mention SLC. There are different versions of the SLC that have different connection requirements. We can better help you if you can tell us what you have.
For example: 5/01 5/02 5/03 5/04 5/05 Micrologix OG |
#3 |
![]() Join Date: Nov 2005
You should have at least one serial port which some notebooks do not offer anymore. That can be overcome with a USB to serial adapter. You need an ethernet port. AB post its requirements for AB software but many notebooks have enough resources to handle AB programs. AB is not into VISTA. The only AB program that I have had speed problems with is RS5000. I have to wait 30 or so seconds for the program to boot. After that I have no speed problems. Making a recomendation for a particular notebook is a personal preference issue. I am partial to Toshiba Satellite Pros but there are plenty of other good laptops and notebooks around. If you go into a rough environment you may want to consider a hardened laptop. Panasonic makes a Toughbook. General Dynamics makes a semitough laptop but I am not convinced yet how good they are. I have only seen a few and I haven't heard enough to say that it is a good laptop. If the PLC's that you encounter have something other than ethernet ports or RS232 (DF1) ports you will just need to buy the external adapter that AB offers.
#4 |
A USB floppy drive will suit most applications. As for the rest of it, all I can suggest is Windows XP Pro and something with a serial port. I don't have a serial port on this Laptop, but I have a couple of different USB interface cables and such for my PLCs.
__________________
"So....Who have you invited to the BBQ in your power supply?" |
#5 |
Like others have suggested:
Windows XP Pro Floppies are not really required anymore, I have never used mine, but it doesn't hurt to have a USB one handy. 1 real serial port You can never have too much RAM (not so much for Rockwell, but for Windows in general. And on Opraghosts post, if we know what hardware you are working with, then we can suggest any extra hardware for communications. |
#6 |
if all your doing is micrologix and SLC's via the Df1 port only then you also need two cables 1747-pmo2 (micrologix cable) and trhe 1747-cp3 for Df1 channel on the SLC's Attached is a listing of the various cables needed for AB select from this list which processors your going to be working on
#7 |
I would go for a Dell with built in serial port, they seem to work well with Rockwell Flakeware.
Roy |
#8 |
One thing I have not seen mentioned...
If you are using this for troublehsooting then go for the biggest screen you can get your mitts on. You will want to display ladder files, data files, and trends all at the same time, so the more screen you have the better.
__________________
True craftsmanship is only one more power tool away. That's the beauty of processors, they don't have emotions they just run code - The PLC Kid. |
#9 | |
Quote:
__________________
Work to Ride, Then Ride to Work |
#10 |
![]() Join Date: Jan 2006
I'll second the recommendation for the Dell Latitude D6xx or D8xx. Pretty reliable and lots of common parts with the other Latitude D series.
#11 |
![]() Join Date: Oct 2005
One more vote for the Dells.
I have both D6xx and D8xx. Have had no issues with any software so far even some legacy stuff due to the true serial port. Plus, the PCMCIA slot comes in handy for most comm cards out there. |
#12 |
Thanks for all the help. I took a look at alot of the equipment and we have the full range of the 500 series stuff,micrologix 1000,1200,1500 and also some of the 5000 series with device net. Is a floppy drive needed to put a key in or can it be done with a usb memory stick? We haven't purchased the software yet I am just trying to make sure we get a notebook that will meet our needs.
#13 |
If you buy the software today it will come with an internet based activation scheme (AB software that is).
No need for the floppy as you get it done via the internet. Though, you can buy a USB floppy at a computer/electronics store at any time. I did not get a floppy for the Dells, just got one from Comp USA I think. |
#14 | |
Quote:
You should be able to get above this now. |
#15 |
AB stuff to carry
Not a problem for a in-plant guy but I got my new HUGE screen laptop. The damn thing is to big for my best backpack. I know it is a small price to pay but I really loved that backpack.
I carry the following in the AB toolbox. DPS1 & 2 port splitters. They are a must for troubleshooting while the operator still runs the machine. USB to DH485 I can't remember the numbers. USB to RS-232 (hint hint look at geniusintraining) Null modem adapter 232 Cable I carry the short CP3 and PM02 and 3 or 4 other common ones (1' less room in the travel box) KFD for devicenet haven't gotten a USB yet PCMK for DH+ (There is a USB version that is less $$$) Then a bunch of DNI, ENI & AIC+ stuff. Just my half a cent worth of stuff that I carry. Anybody else have some goodies that are a must to carry?
__________________
There should be a minimum IQ before people can breed |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Can't connect Allen Bradley to Telemecanique | Madahbee | LIVE PLC Questions And Answers | 10 | August 13th, 2008 08:27 AM |
| Allen Bradley 256K PCMCIA Memory Card | noorgul | LIVE PLC Questions And Answers | 1 | March 22nd, 2007 09:16 AM |
| Wonderware 7.11 with Siemens S7 400 and Allan Bradley plc | shandra_ck | LIVE PLC Questions And Answers | 3 | September 5th, 2005 08:39 PM |
| Dell notebook AC adapter recall | Contr_Conn | LIVE PLC Questions And Answers | 8 | October 12th, 2004 08:54 PM |
| Wincc 6.0 and Allen Bradley PKTX 1784. | nistam | LIVE PLC Questions And Answers | 1 | March 31st, 2004 10:19 AM |
