plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old September 24th, 2008, 09:22 PM   #1
chue.lee
United States
chue.lee is offline
factory talk view studio doesn't import all tags
I tried importing some timer tags into factory talk but only 4 or 5 of them came up. I'm trying to use the tag name for the timer to allow the user to see the default preset and be able to change the preset from the touchscreen. My question is, how do I get all the timer tags or all the tags into the factory talk view studio database? thanks
Old September 25th, 2008, 03:16 AM   #2
fuzzy logic
Italy
fuzzy logic is offline
fuzzy logic's Avatar
Hi, at first, three questions :
1. Which data server are you using?
2. Which PLC does the View connect to?
3. Which FactoryTalk View you mean (SE or ME)?
In FactoryTalk View, you have the option to not create an HMI database for the tags, but you can point to the PLC database directly, and see all what is down there.
You have to configure your Data Server (i.e. RSLinx OPC server / RSLinxEnterprise) and you can then browse for the tags in the PLC.
Or you can use an offline file from the PLC to get its tags.
- fuzzy logic
Old September 25th, 2008, 06:46 AM   #3
rdrast
United States
rdrast is offline
rdrast's Avatar
How exactly are you importing them?
From what PLC?
And Fuzzy, for timer presets and such, it's very handy to bring them into the tag database... Set the 'Scale' to 0.001, and deal with Logix timebase and accumulated values directly in seconds.
Old September 25th, 2008, 07:07 AM   #4
fuzzy logic
Italy
Wink
rdrast, you're right
There are also other methods to do this... keeping Direct Tag Referencing (that optimizes performances and also leaves you more free time )
Here attached is an example...
- fuzzy logic
Old September 25th, 2008, 07:18 AM   #5
rdrast
United States
rdrast is offline
rdrast's Avatar
With all due respect, that is kludgy, and plays total havoc with the 'Tag Replacement' function.
I gave Direct Tag Referencing a shot on two or three large projects, and have since completely abandoned it as an unmaintainable waste of time. I know there are other opinions, but really... I can't stand it.
I generally use the Import/Export utility (which, of course is partially broken) and fix up the imports in Excel. Then I can use the same tag database to import to ME and SE projects. Then I go ahead, and create most of my displays in ME, so they are importable to SE... The whole system is actually pretty kludgy
Oddly, I do use direct referencing for almost all of my VBA database work, but there I'm working with code in one defined place.
Old September 14th, 2011, 08:17 AM   #6
Silence89e
Iraq
Silence89e is offline
hi.... i have a similar problem, the case is am trying to connect factorytalk hmi with codesys v2.3, but i cant import tags from codesys to factorytalk.
codesys has an OPC server, and thus it should allow it to cannect to the factorytalk.
so what should i do???? pleas....
best regards.
Old September 14th, 2011, 09:01 AM   #7
rdrast
United States
rdrast is offline
rdrast's Avatar
best regards.
You don't "Import Tags" via an OPC connection, FTView isn't nearly that smart.
Right click your project tree somewhere, and add the codesys OPC server. Then you should be able to access it.
__________________
How to ask questions the SMART Way!
Look First, Ask Second!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Factory Talk Studio 5.00 gosenbach LIVE PLC Questions And Answers 14 March 17th, 2009 07:30 AM
Factory Talk View Studio on screen keyboard kedarkg LIVE PLC Questions And Answers 2 September 16th, 2008 03:08 PM
Factory Talk View Studio VBA to access HMI or PLC tags djpalaz LIVE PLC Questions And Answers 0 December 14th, 2007 07:57 AM
Factory Talk View Studio HMI tags djpalaz LIVE PLC Questions And Answers 4 December 6th, 2007 01:59 AM
Factory Talk View Studio import ?? 504bloke LIVE PLC Questions And Answers 4 November 28th, 2007 08:50 AM
