This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
RSView32 & MicroSoft Forms 2.0 ListBox
I cannot get a Microsoft Forms 2.0 activex listbox to populate from VBA code. I am using RSView32 version 7.4. I can get text to populate in it from a command button, but not from VBA. Here is my code that adds a blank line, but no text to the listbox:
Dim tagTemp_Ingredient As tag Set tagTemp_Ingredient = gTagDb("RECIPE\Temp_Ingredient") tagTemp_Ingredient.Value = strRecipeValues(1) 'this string variable is populated through other code, I checked and it always 'contains a value gCommand.Execute ("Invoke Admin.ListBox1.AddItem(Temp_Ingredient)") Set tagTemp_Ingredient = Nothing I do not think I can populate the listbox from the invoke command in VBA with a VBA native value such as strRecipeValues(1) (string array). I think I need to use a tag. I have the Temp_Ingredient tag assigned to the value parameter in the ListBox1 properties. Thanks |
#2 |
gCommand.Execute ("Invoke Admin.ListBox1.AddItem(Temp_Ingredient)")The Temp_Ingredient is located in a root folder which I did not insert in its path. It is now working. RECIPE\Temp_Ingredient is the tag. That was only about 2 hours going around in a circle. Live and learn.
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| RSVIEW32 database load problem | gizmo | LIVE PLC Questions And Answers | 5 | October 30th, 2012 01:26 PM |
| Microsoft ComboBox in RSView32 Application | plcnovel | LIVE PLC Questions And Answers | 5 | February 23rd, 2007 05:24 PM |
| Mirroring RSView32 Web Server | PCTDavis | LIVE PLC Questions And Answers | 0 | January 7th, 2004 08:08 AM |
