This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: Oct 2008
PanelView 550 Comm problems
The other day, a SLC 500 had a 5/02 processor fail. We were using the 1747-AIC to communicate to a PanelView 550 (P/N 2711-B5A3).
I am now trying to utilize a 5/03 processor in place of the 5/02. I am using the DH 485 Comm protocol. The PanelView is telling me no nodes are found on the network. I am pretty darned sure I have all the nodes numbered correctly but I have found in the past making these sorts of asusmptions can be dangerous. Don't be afraid to treat me like I'm stupid. These are the first A-B products I've used. I'm more of a GE kinda guy. We bought these machines very, very used and I'm just trying to keep 'em running. |
#2 |
You may need to use the PanelBuilder software to open your Panelview application and check the communication settings. In that section, you will find the node number that the Panelview expects the SLC to be, and you may also need to update those settings to tell the Panelview you are communicating with a 5/03 rather than a 5/02.
Good Luck, Jeff
__________________
To the optimist, the glass is half-full. To the pessimist, the glass is half-empty. To the engineer, the glass is twice as big as it needs to be. |
#3 |
![]() Join Date: Dec 2004
You must have restored the 5/03 with the 5/02 program so just make sure the 5/03's node address is the same as the 5/02. It should be in the original program but you'll have to manually change the 5/03 to match what it was; downloading doesn't change the comm port settings IIRC.
__________________
"You can live to be a hundred if you give up all the things that make you want to live to be a hundred." Woody Allen |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Panelview - PC : Comm Problems | mrhhassan | LIVE PLC Questions And Answers | 12 | October 25th, 2009 02:03 AM |
| Panelview 550 problems | DalTile | LIVE PLC Questions And Answers | 1 | August 25th, 2006 07:26 AM |
| block transfers to panelview 550 | bakerboy_99ca | LIVE PLC Questions And Answers | 1 | February 15th, 2005 10:55 PM |
| PanelView 550 Problem | Tom Jenkins | LIVE PLC Questions And Answers | 15 | August 16th, 2004 12:42 PM |
| HMI to Database alarms & comm problems | philjf | LIVE PLC Questions And Answers | 0 | April 8th, 2004 09:34 AM |
