plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old November 19th, 2008, 12:31 PM   #1
jimmycooker
Ireland
jimmycooker is offline
Valid node numbers are between 0 and -1
I have established a connection through rslinx.
When i try to configure the DH-1 driver with a node address by going to system options & system communications it will only let me enter a 'Valid node numbers are between 0 and -1'.
When i try to go online in RSlogix 500 with a node address of -1 i get the following message:
No response from processor at selected path/node
cannot connect to remote emulator.
Can anyone tell me what i'm doing wrong?
Old November 19th, 2008, 12:44 PM   #2
ewb_3
United States
ewb_3 is offline
ewb_3's Avatar
If you are using the DF1 driver, you need to use autoconfig. Use a Null modem cable between the processor and your computer, use RSlinx to connect to the SLC. Go to Communications then configure drivers then choose the Rs232DF1 driver. Auto config. Unless the SLC500 port was used for DH485, it will work. Otherwise, you need to use the 1747-Pic/AIC+ driver. Good luck
Old November 19th, 2008, 12:50 PM   #3
jimmycooker
Ireland
I already have the driver configured and can see the SLC 5/03 as node 1 in RSlinx (laptop is node 0).
Problem is that RSlogix 500 will not allow me to assign node 1 to the driver, only -1.
Old November 19th, 2008, 12:55 PM   #4
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
RSLogix500 does not assign node numbers to the device on the network, only to the communication channel for an offline file to be downloaded.
If you are trying to go online with a running processor, close any open file you have opened and then go to the who active screen and select go online from there.
__________________
It's not all the variables I am most concerned with, it's the undiscovered constants.
Old November 19th, 2008, 12:55 PM   #5
jimmycooker
Ireland
I thought i had a resolution when i saw this:
http://forums.mrplc.com/index.php?ac...e=post&id=5852
But i am running version 7.10 build 9
Old November 19th, 2008, 12:57 PM   #6
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
RSLogix can get you cornfused when you go online, depending on what the open file says about the system communications.
Are you trying to connect to an emulated PLC? or a real one?
__________________
Old November 19th, 2008, 12:59 PM   #7
jimmycooker
Ireland
In RSlogix 500 if you go:
Tools
Options
System Communications (Tab)
you have:
Driver Route Processor Node
AB_DF1 Local -1d
The minus one came from the initial choice i was forced to make between 0 and -1...
Is this correct? The CPU node should be 1 shouldn't it?
Old November 19th, 2008, 01:02 PM   #8
jimmycooker
Ireland
I can't go online in rslogix 500, i get the errorNo response from processor at selected path/node
Old November 19th, 2008, 01:02 PM   #9
jimmycooker
Ireland
its a real PLC
Old November 19th, 2008, 01:11 PM   #10
Michael Hunt
United Kingdom
Michael Hunt is offline
What cable are you using? Is it serial port or DH+ port.
Old November 19th, 2008, 01:13 PM   #11
jimmycooker
Ireland
One of these:
http://www.plccables.com/allen-bradl...-1747-CP3.html
Old November 19th, 2008, 03:30 PM   #12
ewb_3
United States
ewb_3 is offline
ewb_3's Avatar
Lightbulb
Do a search and find the two Harmony files. Delete them. With Linx off. Linx will re-create the files when you start it up again. It might have gone into confusion with the changes.
Old November 19th, 2008, 03:42 PM   #13
jimmycooker
Ireland
I did a search but culdn't find those files...
Old November 19th, 2008, 03:47 PM   #14
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
When you go online from RSLogix, are you going through the Comms -> Who Active Go Online menu option?
If so, you should be able to select the processor from the DF1 driver in a RSLinx Who Active window.
Just changing the RSLogix mode selector from OFFLINE to ONLINE will try to use the System Comms settings which are, apparently, set up for emulator mode in your case. So, don't use that method to go online, go through the RSLogix "Comms" menu item, then the "Who Active Go Online" choice.
Paul
__________________
Old November 19th, 2008, 03:53 PM   #15
jimmycooker
Ireland
Paul
I cannot go online in RSLogix...i will post some pictures
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
