plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old November 24th, 2008, 03:23 PM   #1
controlled
Canada
controlled is offline
Problem installing SSD configEd lite
I am trying to install ConfigEd lite for SSD Drives.
I am using a Dell lattitude D830 with XP pro SP 2.
I install the CD, and it asks me to verify that I want to extract the files and install. I click OK. and it extracts 100% of files, but then does nothing.
Is anyone familiar with this software, and would have experienced the same thing?
Derek
Old November 24th, 2008, 08:41 PM   #2
bkottaras
United States
bkottaras is offline
Derek
If this isn't an auto installer package, you may need to find out where (location/folder/etc) the files are getting extracted to, navigate to the folder when the extraction is done and look for a setup.exe file
Old November 25th, 2008, 02:15 AM   #3
504bloke
England
504bloke is offline
504bloke's Avatar
You would be better downloading DSELite.
http://www.ssddrives.com/usa/softwar...te_Install.exe
Im pretty sure DSELite now supports all drives.
CEDLite has an install help here
http://www.ssddrives.com/usa/softwar...ll%20Notes.hlp
Is there a particular reason you want CEDLite because as far as i know it is no longer being updated due to DSELite?
__________________
Regards
Dave
"When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity."
Albert Einstein (1879-1955)
Old November 25th, 2008, 06:23 AM   #4
controlled
Canada
Thanks for the link Dave, DSElite installed perfectly.
I only have 2 SSD drives installed, and have only had to use the software once, which was CElite. I wasnt aware of DSElite. As far as just uploading the current configuration, and downloading to a new drive, are the steps involved the same as using CElite?
Old November 25th, 2008, 11:51 AM   #5
504bloke
England
504bloke is offline
504bloke's Avatar
Depends which drive and how you connect ?
Im guessing the rs232 ssd cable and 690,650v or 590 ?
I havent got DSELite installed as it didnt play nicely with DSEFull on my home pc and havent used it for a while so cant answer till tomorrow, but from memory its pretty much the same, dselite is more windows orientated though and nicer than cedlite.
Drop down command menu and options are extract, full install and install.
For serial comms setup go to View > Properties > Global Settings > Serial Comms port
One thing thats far better than cedlite is the auto baud when on serial comms.
Use Shift+PgUp or PgDn to scroll through the drives different setup pages.
If you have an existing cedlite app you can import it into dselite and then save as a dselite app.
__________________
Regards
Dave
Old November 25th, 2008, 11:57 AM   #6
controlled
Canada
Thanks everyone.
I installed DSElite and was able to upload and download the configuration
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Problem installing S7-PLCSIM 5.3/SP1 stplanken LIVE PLC Questions And Answers 6 August 25th, 2006 09:37 AM
Problem installing Step 7 Dariusch LIVE PLC Questions And Answers 3 June 19th, 2006 02:18 AM
S7 - just for info, curious problem with Labels RMA LIVE PLC Questions And Answers 1 June 29th, 2005 01:02 PM
Ab Plc5 Rio Problem. fernandes LIVE PLC Questions And Answers 5 March 7th, 2004 01:25 PM
PLC5/40 Backplane Problem????? Andrew Evenson LIVE PLC Questions And Answers 18 August 24th, 2002 07:06 PM
