plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old November 26th, 2008, 12:09 PM   #1
MattD
United States
MattD is offline
Downloading to PanelView 600
Panelview 600 (2711-B6C8) has DH+ port and RS232 Printing port. I don't have DH+ capabilities from development PC. I believe I can download to RS232 port using panelbuilder 32. The printing is DISABLED. But I cannot find the PV600 using internal DF1 driver, nor from RSLinx network. What cable do I need? Which driver should I use in Linx? And how should I configure that driver? Thanks for any help!
Old November 26th, 2008, 12:28 PM   #2
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
I believe you need a straight thru serial cable and you need the existing application in the panleview to have the auxillary port usage set to download, if that's what you mean by disabled.
Also, check your comm port selection and baud rate in the transfer utility to ensure they match the existing settings in the panelview.
The easiest way to transfer the application IMHO is via an ATA type PCMCIA memory card if you have one available. You can save the application as a .pva file type, then copy it to the memory card. Insert the card in the panelview and load it from the configuration screen.
__________________
It's not all the variables I am most concerned with, it's the undiscovered constants.
"You can lead a horse to water but if he's got his head up his as$ he may die of thirst anyway."
Old November 26th, 2008, 12:39 PM   #3
MattD
United States
MattD is offline
Thanks Okie
Got it. I was using null modem cable. Straight thru worked just fine. Happy Thanksgiving!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Comm issue between Micrologix 1200 and PanelView 600 edwinmart LIVE PLC Questions And Answers 5 September 13th, 2008 06:37 PM
Downloading to a Panelview 600 louiecypher LIVE PLC Questions And Answers 1 May 22nd, 2008 03:59 PM
Panelview Plus 600 reading from SLC5/03 via NET-ENI story... Jawmunji LIVE PLC Questions And Answers 4 June 20th, 2007 11:30 AM
Panelview 600 with DH+ help LMDAVE LIVE PLC Questions And Answers 7 October 12th, 2006 05:00 PM
connect to Panelview 600 with ethernet bpoon LIVE PLC Questions And Answers 7 April 13th, 2006 03:45 PM
