plc storereviewsdownloads
Reply
Thread Tools Display Modes
Old December 22nd, 2008, 08:09 PM   #1
sparky_289
United States
sparky_289 is offline
sparky_289's Avatar
Cool Excel code for breaking values into bit fields
I'm looking for a fast easy Excel code to move whole integer values into separate bit fields. Does anyone know of a relatively easy code?
Old December 22nd, 2008, 08:34 PM   #2
panic mode
Canada
panic mode is offline
panic mode's Avatar
you can use DEC2BIN to get binary value, then just extract character or bit of interest using MID
Old December 22nd, 2008, 08:35 PM   #3
kolyur
United States
kolyur is offline
kolyur's Avatar
This formula should work:
=MID(TEXT(DEC2BIN(123,8),"00000000"),X,1)
where 123 is the number (could be reference to another cell) and in this case 8 is the number of bits you're working with. X is the position of the binary digit you want to extract (counting from the left/MSB, not the right). In order for the DEC2BIN function to work, you need to have the Analysis Toolpak enabled.
Old December 22nd, 2008, 11:20 PM   #4
TConnolly
United States
TConnolly is offline
TConnolly's Avatar
The attached spreadsheet has a little bit of legerdemain in it in the form of a custom function in VBA.
The function is:
Public Function BITAND(x As Long, y As Long)
BITAND = x And y
End Function
and it is located in Module 1 on the VBA sheets. You will need to have Excel security set to allow macros - I recommend medium so that you get a prompt before opening.
With the custom function any integer can be bitwise ANDed with any other. By ANDing it with 2^n, where n is a bit position, we can determine if that bit is TRUE or FALSE, and return the value 1 or 0 with the Excel IF function.
Just another way of doing it without using TEXT functions. It handles unsigned integers.
Also there is a useful tool called LL-SOLVER that is a free download, you can get it from the dowload section at MRPLC, which is useful for converting and viewing 16 bit integers in hex, decimal, and binary - much simpler than EXCEL for the occasional quick binary conversion.
http://forums.mrplc.com/index.php?download=606
__________________
True craftsmanship is only one more power tool away.
That's the beauty of processors, they don't have emotions they just run code - The PLC Kid.
Old December 23rd, 2008, 11:34 AM   #5
sparky_289
United States
sparky_289's Avatar
This is a great code. Thanks!
Old December 23rd, 2008, 12:28 PM   #6
trishark
United States
trishark is offline
A different approach - no vba
abcdefghijklmnopq1bit151413121110987654321023276816384819240962048102451225612864321684213111111111111111111111111878787872323773104=if(b6=1,a3-b2,a3)56=c3,1,0)">0=d3,1,0)">0=e3,1,0)">0=f3,1,0)">0=g3,1,0)">0=h3,1,0)">1=i3,1,0)">0=j3,1,0)">0=k3,1,0)">0=l3,1,0)">1=m3,1,0)">0=n3,1,0)">1=o3,1,0)">0=p3,1,0)">1=q3,1,0)">1=r3,1,0)">17=b2,1,0)">=if(a3>=b2,1,0)
formula listed below the start of cell/row so visible in this copy. Formulas copied across b3 thru q3 and b6 thru q3. Number to parse goes in a3, row 6 gives bits. Formulas could probably be combined and row 2 numbers hardcoded into formula if you need to get to one line.
Mike
Old December 23rd, 2008, 12:29 PM   #7
trishark
United States
trishark is offline
Well, copy from excel did not work at all. Will attach file.
Old December 23rd, 2008, 12:33 PM   #8
trishark
United States
trishark is offline
another try
another way to skin the cat
Old December 23rd, 2008, 01:44 PM   #9
zova
Russian Federation
zova is offline
zova's Avatar
And this is my code which I use for a long time.
Code:
Function KM(ByVal H As Long, L As Long) As String
' this function returns binary sequence as string
' H - input integer value
' L - length of returned string
Dim k As Long
Dim E As Long
KM = "B"
1:
    E = H Mod 2
        If E = 0 Then
            KM = "0" + KM
        Else
            KM = "1" + KM
        End If
    H = Int(CDbl(H) / 2)
    If H >= 1 Then GoTo 1
k = 1 + L - Len(KM)
While k <> 0
KM = "0" + KM
k = k - 1
Wend
End Function
I was late a little, but I will be glad if it be useful for someone.
Old December 23rd, 2008, 01:59 PM   #10
zova
Russian Federation
zova is offline
zova's Avatar
this is complete Excel book with function above
ps - I'm sorry for russian comments
Old December 23rd, 2008, 04:49 PM   #11
TConnolly
United States
TConnolly's Avatar
So far we have 100 ways to skin that cat, need to make it 101 just to be cliche.
__________________
Old December 24th, 2008, 07:27 AM   #12
henry5674
United Kingdom
henry5674 is offline
Some more skinned cats
I normally use the ^ (power of) operator when decoding binary to/from decimal. There are three functions on the sheet, Decimal to binary,Binary to decimal and a function to check a bit status in a word.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Alarm Code mwatkins LIVE PLC Questions And Answers 27 October 15th, 2019 03:44 AM
Automatin Direct Changes Download ArikBY LIVE PLC Questions And Answers 53 May 12th, 2004 01:05 AM
Internal addresses rogerhollingsworth LIVE PLC Questions And Answers 5 August 10th, 2003 07:02 PM
Looping VBA code in Excel pagewe LIVE PLC Questions And Answers 8 February 10th, 2003 11:19 AM
Auto generate code in Excel? PhilRey LIVE PLC Questions And Answers 9 January 17th, 2003 07:32 AM
