plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 12th, 2009, 08:19 AM   #1
Gromit
Austria
Gromit is offline
WinCC Flexible
Hello,
I'd like to use the WinCC Flexible / Archive option for logging an important parameter (analog value) every 30 sec.
Can I make a trend view and see how the imporatant parameter changes several days/weeks ago?
I know that WinCC Flexible does not have SQL built-in. What in fact is the Flexible limitation (compard with WinCC)?
Thank you in advance
Old January 18th, 2009, 11:19 AM   #2
falgunvasava
India
falgunvasava is offline
simply log the data in datalog or *.CSV file.get the trend view in a screen and in the properties->trend ,select the log instead of realtime.
Use an internal tag of entering date and time.enter the tag in the properties of X-axis.
Old February 25th, 2009, 05:51 PM   #3
nehe bhimaji
India
nehe bhimaji is offline
nehe bhimaji's Avatar
Dear Sir
I have the same problem to see the past trends.As i follow your idea but still not success
As x axis scaled by internal tag in time format the trends in log class is not accepting that
Any suggestion or another idea???
Old March 2nd, 2009, 01:00 PM   #4
falgunvasava
India
dear nehe bhimji
i am not clear about exact problem you are facing.
check
1)if you have selected your file with enough no. of data records i.e. in historical data->data logs.
2)enable logging at run time start is selected 'on'.(its up to your need)
3)you have to select the data log you created in the property of the tag
and the acquisition mode.
4)in the property of trend view->trends->trend type.here select "log'
in the "source setting" you select the data log you created under log and select the tag you want to read from the log under log entry.make sure that the tag you want to read is logged exactly in the same data log you selected.
please give detail where you are stuck up if there is still a problem.
Old March 4th, 2009, 07:11 AM   #5
nehe bhimaji
India
Thumbs up
Dear falgunvasava
You are right,I have configure the log and trend view correctly and it is working fine but my problem is as below
1.How can i jump directly to see e.g last week traind without scrolling by arrow key in traind view?
As you say
Use an internal tag of entering date and time.enter the tag in the properties of X-axis".
Pls give clear procedure how to configure date and time on x axis to jump directly to past record
If you have any example pls mail or guide
Nehe
Old March 4th, 2009, 11:48 AM   #6
falgunvasava
India
1)create an internal tag with "Datetime" data type.
2)Select trend view,go to properties->Axis,here you will find "X-axis".You can select the tag you created in front of "external time".
3)now just make some space in the screen of your trend view and put a date and time field .Goto "general"setting for the field , mode :input/output,format:tick both dispay date and time,process:use tag ,and select the tag you created.
4)you can also show the system time with another date and time field just above the first one as output mode so that it is helpful to enter the date and time in the required format.
5)finish...........start runtime and enter your date.
Old March 6th, 2009, 11:30 AM   #7
nehe bhimaji
India
Thumbs up
Solved my problem
Nehe
Old September 12th, 2009, 03:55 AM   #8
nehe bhimaji
India
Thumbs up
Dear Sir
As i go to see the log value in the trend by entering the date it will take long time and only display the picture of clock (Somthing like searching the data)say 7 to 10 sec to display the historical trend.How can I speed up or ignore this delay
And I observe this delay start increasing as log aprroches to full
Pls suggest
Nehe
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Citect Vs WinCC - Long Doug_Adam LIVE PLC Questions And Answers 22 October 3rd, 2014 12:56 PM
Why cant OPs state the "Flexible" in WinCC Flexible ? JesperMP LIVE PLC Questions And Answers 0 August 5th, 2008 01:41 AM
Anyone tried WinCC Flexible and OPC ? JesperMP LIVE PLC Questions And Answers 4 July 20th, 2007 10:40 AM
WinCC Flexible Quirks tvey LIVE PLC Questions And Answers 5 May 3rd, 2007 05:57 AM
Simatic Wincc Flexible 2004 -->2005 STL??? LIVE PLC Questions And Answers 8 August 29th, 2006 05:42 AM
