plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 18th, 2009, 09:15 AM   #1
c4guy
United States
c4guy is offline
c4guy's Avatar
Renaming an RSview project
Hello all,
I started an Rsview project which was supposed to be just a test project that I was playing around with to learn the program. Well the program evolved and turned into something usefull. I named the project to reflex my original intentions but now it does not fit the result. Like I mentioned I am just learning the software so I hope the answer isn't too obvious but I cannot figure out how to rename the project. I am using RSview32 works edition. I am also having an issue with moving the project to another PC. I seen in another thread that there is a tool to transport the project. I looked in my RSview tools directory and there isn't anything there that would allow me to do that. Do I just copy the whole project folder? I also seen something mentioned that AB writes to some registry keys when it saves a program which is why you have to move the file with thier tools...is this true? Thanks for any help
c4guy
Old January 18th, 2009, 10:14 AM   #2
bernie_carlton
United States
bernie_carlton is offline
bernie_carlton's Avatar
EDIT: You may wish to ignore this -and follow the next post
I don't have the program in front of me and I've only worked with RSViewStudio ME so this may not totally applicable, but this is what I would do.
Close the application you are working on. No applications should be open but the RSView program itself should be open.
Under 'Tools' should be something named 'Application Manager'. In here are the tools you need. You can rename your project. Also you have the tools to transport your project to another computer which runs RSView. These are 'backup application' which makes a compressed version of the entire application including necessary registry entries. This creates a single file with an 'apa' extension. This 'apa' file is what you must copy to the target computer. Once there you can use the 'application manager' on that machine to 'restore' the application. This will not only recreate the directory structure it will also install the necessary registry entries.
Note that 'application manager' is also the tool to delete a project. Don't try to delete one just by deleting the directory structure. Many records will be left in the registry and RSView will be hopelessly confused.
EDIT: follow the next post. It appears tomalbright has experience with you exact configuration.
__________________
Controlling outputs is the PLC's way of getting its inputs to change.
www.thePLCguy.com
Old January 18th, 2009, 10:33 AM   #3
tomalbright
United States
tomalbright is offline
RSView32 lets you copy the whole darn thing. I regularly zip and unzip the closed project to other computers.
I'm not sure about newer versions, I am using 6.3 with no issues regarding transfer. The only thing about renaming is to simply save the file with another name. Also, just rename the filename (project.rsv) itself with Windows. There's nothing in the RSView file regarding its own name. You might run into issues with RSLinx and any topics that look for your RSView configuration, but that's fairly rare, I think.
__________________
"We really don't care how you program your PLC, just don't blow yourself up!"
www.GeekQuake.com Also on Facebook!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Get RSLinx Project name in RSView FKelly LIVE PLC Questions And Answers 1 May 14th, 2008 09:30 AM
How Can We Edit The Project Of Rsview Me siva_maddala LIVE PLC Questions And Answers 7 April 4th, 2007 05:22 AM
RSView 32 Project auto startup mikedba LIVE PLC Questions And Answers 4 February 28th, 2007 10:10 AM
RSView Studio 3.2 SE Distributed Project Transfer Help! Doughy LIVE PLC Questions And Answers 3 January 17th, 2007 01:11 PM
How to start up a RSVIEW project ? sHAWN YI LIVE PLC Questions And Answers 6 January 23rd, 2004 07:29 AM
