plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 7th, 2009, 11:50 AM   #1
moody088
United States
moody088 is offline
S7-200 connection
hi everyone ,,,,,
how can i connect PLC S7-313C with S7-224 cpu via MPI connection? does this need SIMATIC MANAGER or microWIN ?,,,,,
Old February 7th, 2009, 12:29 PM   #2
Clay B.
United States
Clay B. is offline
Clay B.'s Avatar
S7-200 is programed in MicroWin. I have always connected using PPI. I do not think you can program thru and MPI but there are others who can give you a more definate answer on that.
Old February 8th, 2009, 03:25 AM   #3
ramaslabas
Lithuania
ramaslabas is offline
ramaslabas's Avatar
Connection
Hi
MPI for Microwin,
transmission rate standart for S200 is 19,5 Kbps.
If to set higher you will not be able to conect with PPI cable
Regards
ramaslabas
Old February 8th, 2009, 05:13 AM   #4
dchartier
Canada
dchartier is offline
Hello Moody;
Follow this link to the Siemens support webpage; here is a FAQ showing how to use functions in the S7-300 (X_PUT and X_GET) to read and write data to a S7-200 CPU [so the programming for the comm functions is done in Step 7 Simatic Manager]:
http://support.automation.siemens.com/WW/view/en/747743
Hope this helps,
Daniel Chartier
Old February 8th, 2009, 06:40 AM   #5
geniusintraining
United States
geniusintraining is offline
geniusintraining's Avatar
Quote:
Are you wanting to network your PLC's?
__________________
www.PLCTrainer.net
PLC Trainers, Communication Cables and Automation Supplies, Allen Bradley ~ Siemens ... YouTube PLC help videos.. http://www.ind-concepts.com/Support_and_Downloads.htm
Old February 8th, 2009, 09:28 AM   #6
moody088
United States
moody088 is offline
yes i want building a network as i mentioned
i want the hardware configuration as well as software configuration (dchartier)
and i need to use microWIN ??
Old February 8th, 2009, 11:36 PM   #7
manmeetvirdi
India
manmeetvirdi is offline
Hi there
I think EM 277 will do. I have used this to connect 300 and 200 with profibus. But if you see technical specification of this EM277 its written that it supports both MPI and profibus.
* For connection of the S7-22x to PROFIBUS DP (as slave) and MPI
* Can be simultaneously operated as MPI slave and DP slave
* Transmission rate max. 12 Mbps
* Can be used with CPU from version 6ES7 22x-xxx21-xxxx
I cant figure it out how I can connect Em277 with MPI though. Because in Net pro if I try to connect EM 277 module to MPI network it comes up with the message:
"You have to either select a DP module with a DP master system or DP slave in order to place a DP slave"
Bold part sounds like if you dont have DP port then you need to use DP Module CP 342-5 with 313.
Would like to know how EM277 can be connected to MPI n/w.
Edit:It seems that if you want to connect 200 to 300 then simply connect MPI port of 300 to Port 0 or 1 of 200. Make sure that this port of 200 has baud rate of 187.5Kbps. And then use X_PUT and X_GET instructions in 300 to communicate.No need of EM277.
Here is the link http://support.automation.siemens.com/WW/view/en/747743
__________________
Manmeet
Old February 10th, 2009, 12:14 PM   #8
moody088
United States
moody088 is offline
ok manmeet
but what is the instruction that i have to use in microWIN to communicate with the S7-300?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
shematic connection PC to S7 200 paris LIVE PLC Questions And Answers 29 October 31st, 2008 02:45 PM
Any display with Siemens S7 200?? Preeya LIVE PLC Questions And Answers 6 January 14th, 2007 05:10 AM
Siemens CP343-1 U_SEND & U_RECV and S7 connection protocol Esa LIVE PLC Questions And Answers 6 August 14th, 2006 03:19 AM
s7 200 master - slave Farid LIVE PLC Questions And Answers 1 March 14th, 2004 11:09 PM
S7 200 communications !! Smdolby LIVE PLC Questions And Answers 4 January 31st, 2004 08:36 AM
