This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: Jun 2008
please help me
i have plc simatic s7 cpu 416-3dp alawys the program on cpu failed and all leds flashes
note i use ram card in cpu (mc p51/2mb/ram) if i can replace this ram with flash card plese tell me how and type of flash |
#2 | |
![]() Join Date: May 2003
Quote:
First, EPROM cards for the S7-400 CPUs: 6ES7952-0KF00-0AA0 SIMATIC S7, MEMORY CARD FOR S7-400, LONG VERSION, 5V FLASH-EPROM, 64 KBYTES 6ES7952-0KH00-0AA0 SIMATIC S7, MEMORY CARD FOR S7-400, LONG VERSION, 5V FLASH-EPROM, 256 KBYTES 6ES7952-1KK00-0AA0 SIMATIC S7, MEMORY CARD FOR S7-400, LONG VERSION, 5V FLASH-EPROM, 1 MBYTE 6ES7952-1KL00-0AA0 SIMATIC S7, MEMORY CARD FOR S7-400, LONG VERSION, 5V FLASH-EPROM, 2 MBYTES 6ES7952-1KM00-0AA0 SIMATIC S7, MEMORY CARD FOR S7-400, LONG VERSION, 5V FLASH-EPROM, 4 MBYTES 6ES7952-1KP00-0AA0 SIMATIC S7, MEMORY CARD FOR S7-400, LONG VERSION, 5V FLASH-EPROM, 8 MBYTES To load the program into the EPROM, once you have sloted it in the CPU, use the "Copy RAM to ROM" command in Step 7 Simatic Manager. Now, the most important issue. Why is your CPU failing? With all LEDs flashing, this means a catastrophic unrecoverable fault... Have you opened the Diagnostic Buffer of the CPU to look at the system messages that are collected there? If you have the required OBs loaded in your user program, the Diagnostic Buffer should have details on the cause of the problem. The easiest way to open the diagnostic buffer is to go Online with the CPU while looking at the HWConfig editor. Double-clicking on all the modules that show up with a red cross will get you diagnostic information on each of them. You can save the logs (as text files)and show them here if the messages are hard to understand, we have some experience here on the forum. And we are willing to help. Hope this helps, Daniel Chartier Last edited by dchartier; February 10th, 2009 at 03:03 AM. |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
