plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 24th, 2009, 08:58 AM   #1
easingwm
Sweden
easingwm is offline
Help converting STL on Siemens S7-300 to ladder
I have been given the task of implementing some limited changes to an existing Siemens S7-300 application. The program was created around 2002 and I have no way of getting support from the original programmer.
Whereas I have no problem understanding and making changes in the Ladder code, when it comes to STL I'm at a complete loss. As it doesn't seem possible to convert STL to Ladder in the Step7 environment or via an external translator, I would be eternally grateful for any help converting the following STL code to Ladder:
A #Startorder
A #Enable
O #Hand
= L 0.0
A L 0.0
A #MatarpumpFlodesvakt
S #Startorder_pump
A(
A #Startorder
A #Enable
O #Hand
NOT
R #Startorder_pump
NOP 0
A(
A(
O(
A L 0.0
FP #PulsG1Q1B
O #Q1B_hand
S #Tatnings_vatten
A #Tatningsvattenstopp
R #Tatnings_vatten
A #Tatnings_vatten
L #G1G1Q1B_time
SD "G1G1Q1B_time"
NOP 0
NOP 0
NOP 0
A "G1G1Q1B_time"
= #Tatningsvattenstopp
The code regulates the starting conditions for pump operation as well as the supply of seal water to the pump.
Thanks in advance!
Old February 24th, 2009, 09:33 AM   #2
L D[AR2,P#0.0]
United Kingdom
L D[AR2,P#0.0] is offline
The code will convert to FBD:
Old February 24th, 2009, 09:38 AM   #3
Jeebs
Belgium
Jeebs is offline
Code looks like it's written in FBD originally.....
Old February 24th, 2009, 09:50 AM   #4
easingwm
Sweden
easingwm is offline
Red face
That's great L D[AR2,P#0.0], thanks for your help. Strange that I couldn't get the STL code to convert to LAD in Step7. I assumed that if it doesn't convert to LAD, then it also won't convert to FBD, maybe my assumption was wrong?
Old February 24th, 2009, 10:04 AM   #5
L D[AR2,P#0.0]
United Kingdom
Your assumption is wrong. I pasted your code into an FB (having changed the symbol for the timer) and then switched views
Old February 24th, 2009, 10:16 AM   #6
Binaural
Australia
Binaural is offline
If there are elements you can't understand, try copying out bits of the rung into a separate rung and switching views to LAD then.
Old February 24th, 2009, 03:46 PM   #7
easingwm
Sweden
easingwm is offline
In the future I'll try converting STL to FBD as well as LAD to see if it converts.
Once again, thanks for the help.
Old December 16th, 2009, 10:05 AM   #8
simisteven
South Africa
simisteven is offline
converting S7 statement list to ladder
I have read the advice given above but I do not understand how to rename or reconfigure timers, counters etc.
Could some one please explain this by way of example.
I have attached a network for conversion if possible
Old May 20th, 2011, 10:06 PM   #9
mrcaldieri
Brazil
mrcaldieri is offline
hello, I have a program and need to convert to STL LADDER, but this part of the program could not soon understand the red line that is able to convert. Does anyone have any suggestions or could tell me?
A I2.1
A I2.3
S M3.0
AN M1.0
R M3.0
A I1.1
JC M003
A M0.0
M003
A M1.6
AN I1.3
S Q3.2
Old May 21st, 2011, 12:51 AM   #10
L D[AR2,P#0.0]
United Kingdom
Old May 21st, 2011, 11:08 PM   #11
mrcaldieri
Brazil
and this line would look like?
Old May 22nd, 2011, 05:06 PM   #12
STL???
United Kingdom
STL??? is offline
you could at least try for yourself.
Old May 23rd, 2011, 05:22 PM   #13
mrcaldieri
Brazil
Quote:
just check this out. tested in the simulator and I think it worked
Old July 30th, 2012, 02:27 AM   #14
shijith619@gmail.com
India
shijith619@gmail.com is offline
STL to Ladder Conversion
Hii,
Anybody pls help me to convert the STL Program to ladder or FBD. Because iam doing the Program in Siemens 1200 PLC. in that STL Program will not Support.
So Pls help me Convert this.
Thanks in advance.
L #IN0
CAD
DTR
L #IN1
/R
L -900.0
<R
JC M001
TAK
T #OUT2
BEU
M001: L -900.0
T #OUT2
Old February 16th, 2018, 12:44 AM   #15
anurag6042
India
anurag6042 is offline
stl to ladder
A "AKTIV"
A(
O "4U ZY AK"
O "6U ZY AK"
A "M/AUTO"
A "UMS GRU"
A "LIF GRU"
A "TE/LI GR"
A "BR/LI GR"
AN "S 31.13"
AN "KOR FAHR"
= "V ST GRU"
I want convert stl to ladder please help
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
S7 300 program in the arj file format DANGELOUS LIVE PLC Questions And Answers 3 February 8th, 2009 12:56 PM
Ladder vs STL JOLTRON LIVE PLC Questions And Answers 31 March 3rd, 2008 08:52 AM
Siemens S7 300 sparky64 LIVE PLC Questions And Answers 3 May 5th, 2003 03:50 AM
Siemens S7 pointer +stl question DeHulk LIVE PLC Questions And Answers 3 March 26th, 2003 09:29 AM
Siemens Statement list to Ladder utility ranjana LIVE PLC Questions And Answers 9 August 16th, 2002 11:35 PM
