MP277, interactive databasing with csv file's
userxyz
May 2002
any
2,768
Okay, in an other topic I was searching for saving and fetching data out of a database. I was doing it in a PLC, but it eated all the retentive memory of the CPU.
So the idea is writing to csv and reading from it.
I have 5 correctionparameters that I save and retrieve. I write them on a buttonevent and read them when the productcode changes.
This is the write script:
Code:
Dim f, fs, file_path, file_name, file_name_path
On Error Resume Next
Set fs = CreateObject("filectl.filesystem")
Set f = CreateObject("filectl.file")
file_path= "\Storage Card MMC\"
file_name= CStr(SmartTags("ACTIVE BATCH.ORDER_DATABASE.ARTIKEL_NUMMER"))& ".csv"
file_name_path= file_path & file_name
If Err.Number <> 0 Then
 ShowSystemAlarm "Error#" & CStr(Err.Number)&""& Err.Description
 Err.Clear
 Exit Sub
End If
f.open (file_name_path), 2
f.Lineprint (SmartTags("INSTELLING PONSUNIT.CORRECTIES.LINKS.ECS") & ";")
f.Lineprint (SmartTags("INSTELLING PONSUNIT.CORRECTIES.LINKS.HOEK") & ";")
f.Lineprint (SmartTags("INSTELLING PONSUNIT.CORRECTIES.LINKS.HOOGTE") & ";")
f.Lineprint (SmartTags("INSTELLING PONSUNIT.CORRECTIES.RECHTS.ECS") & ";")
f.Lineprint (SmartTags("INSTELLING PONSUNIT.CORRECTIES.RECHTS.HOEK") & ";")
f.Close
Set f = Nothing
Set fs = Nothing
 Err.Clear
 Exit Sub
End If
ShowSystemAlarm "Corrections storage was successful"
So I print 5 line's in a csv, the csv is named after the product (artikelnummer). This is done for retrieving easely.
This is the read script:
Code:
Dim f, fs, file_path, file_name, file_name_path, DataSet,MyZf, field, HiField, i, j
 Err.Clear
 Exit Sub
End If
If fs.dir(file_name_path)="" Then
 SmartTags("INSTELLING PONSUNIT.CORRECTIES.LINKS.ECS") = 0
 SmartTags("INSTELLING PONSUNIT.CORRECTIES.LINKS.HOEK") = 0
 SmartTags("INSTELLING PONSUNIT.CORRECTIES.LINKS.HOOGTE") = 0
 SmartTags("INSTELLING PONSUNIT.CORRECTIES.RECHTS.ECS") = 0
 SmartTags("INSTELLING PONSUNIT.CORRECTIES.RECHTS.HOEK") = 0
Else
 Do While f.eof=False
  MyZf=f.lineinputstring
  field=Split(MyZf,";")
  For i= 0 To 4
   field(i)= Replace(field(i),"","")
   HiField(j,i)=field(i)
  Next
 SmartTags("INSTELLING PONSUNIT.CORRECTIES.LINKS.ECS") = HiField(0,1)
 SmartTags("INSTELLING PONSUNIT.CORRECTIES.LINKS.HOEK") = HiField(1,1)
 SmartTags("INSTELLING PONSUNIT.CORRECTIES.LINKS.HOOGTE") = HiField(2,1)
 SmartTags("INSTELLING PONSUNIT.CORRECTIES.RECHTS.ECS") = HiField(3,1)
 SmartTags("INSTELLING PONSUNIT.CORRECTIES.RECHTS.HOEK") = HiField(4,1)
  j=j+1
 Loop
f.close
End If
Set f = Nothing
Set fs = Nothing
 Err.Clear
 Exit Sub
End If
ShowSystemAlarm "Corrections fetching was successful"
This one doesn't work...
Any ideas please ?
Thanks is forward.
BTW: I never saw a message in the alarm window while system alarms should be shown.
I think this is on a wrong place:
Err.Clear
Exit Sub
End If
And the this is never shown: ShowSystemAlarm "Corrections fetching was successful"
Same for the save, even while it does save...
okay
Okay,
I know a little more now.
Saving works. Systemmessage is shown also
Fetching when the file doesn't exsists sets every value on zero and systemmessage is shown.
But, when fetching, and file exsists, nog systemmessage, none of the scripts is executed anymore, it's a complete scriptstall that I get. I guess there is something not right in the loop...
any help please ?
Err.Clear
Exit Sub
End If
I dont have the time to scan through all your code.
But, isn't what you are trying to do the same as the standard recipe system in WinCC Flex ?
I would definitely use the canned function in stead of rolling my own.
euhm
Not it's not the same. Import and export can do the same, I agree. But you cannot say= now activate recipe xxxx.
A recipe that is made can not be recalled automatically.
I need to fetch the data automatically from the csv file's.
the problem is in this section:
Code:
Else
  For i= 0 To 4
  Next
  j=j+1
 Loop
I rewrote it and now have this in place:
Code:
Else
 For i=0 tor 4
  HiField(i,0)==f.lineinputstring
   SmartTags("INSTELLING PONSUNIT.CORRECTIES.LINKS.ECS") = HiField(i,0)
 SmartTags("INSTELLING PONSUNIT.CORRECTIES.LINKS.HOEK") = HiField(i,0)
 SmartTags("INSTELLING PONSUNIT.CORRECTIES.LINKS.HOOGTE") = HiField(i,0)
 SmartTags("INSTELLING PONSUNIT.CORRECTIES.RECHTS.ECS") = HiField(i,0)
 SmartTags("INSTELLING PONSUNIT.CORRECTIES.RECHTS.HOEK") = HiField(i,0)
 Next
I'm trying to read 5 values in column 1, allways row zero.
I get: type mismatch now
I dont understand what you say there. But if you mean that the PLC cannot interact with the recipes without user interaction, then I think that it is possible.
There are functions such as GetDataRecordFromPLC, and SetDataRecordToPLC, and these can be set to be triggered from the PLC.
However, I have never used the recipe system myself, so I dont know if there is a catch somewhere.
hmm
when you make a new record in a recipesystem, and you had 5 records allready, then it will be record 6. When you've given a 'product number' as recordname, then it's not possible to recall the record by this 'product number'. Another problem is that you can have 300 records I think / recipe. That's way too less.
This part you would have to do in a script. However it should be simple to loop through all recipes to search for the matching number.
I see, yes your requirements are a bit high. There is reserved 64kB for recipes on an MP277. You probably exceed that. On a PC RT there is not this limit. You could switch to a panel PC if you need to.
If I understand well, you would export and import recipes and get the right record...
For example: they are running product x for customer y.
Then I could build recipes / customer and the records are products.
If they activate a product, I could look for the right import and the right record. It's not very easy if u ask me
I would use the LoadDataRecord function.
I just notice now that you can specify the record to load by number or by name. So you dont have to search through all records by the number.
To me it looks as you can do everything with the system functions. It makes sense.
ok
okay,
I agree, I just checked too, and you're right, it is possible to call a record by name.
But, I'm limitated to 500 records in an MP277... that's way to less, they want at least 10000 products
64K integrated Flash, but it says expandable ?
My MMC is 1G
10000 products ! And you say 'at least' !
You have to change your strategy here. Forget about doing this in a "flat" file. You will never get a reliable system that way. And you will spend way too much time with it.
You need to have an SQL database for that many records.
I just tried FactorySQL from Inductive Automation. I is not cheap, but very easy to use. So I recommend it. There are other solutions too.
Office
In the office I have orders / customer. An order is a recipe with several products. I import and export recipes with buttons todo this. This works fine. I hope I can keep this in the office side ? These are flat file's too and works fine...
For saving many many productcorrecttions on MMC or networklocation, isn't this the same, if it works for one, why not for all ?
hmm... I cannot buy other things, if the corrections cannot be linked without extra tools, then it will be without automatic corrections. I tried in the PLC too, but this takes all the retentive memory.
You will never get a reliable system === why not ?
Good day, May I ask, what do I need to perform MIGRATION of HMI program from Siemens MP277 10" Touch hmi to TP1200. I already have WinCC Flexible...
160
Hi All, I currently have an damaged MP277-8" Touch panel (6AV6 643-OCB01-1AX1) which I am able to backup (.psb) via ProSave. We are in the...
2,828
I have HMI MP277 10" Touch and need to connect it with a S7-300 PLC on Profibus NETWORK - I am using TIA Portal V13 and tried to use the Device...
1,028
I need some clarification about uploading the HMI file from a Siemens MP277 to edit it in WinCC. Although the machine manufacturer is no longer in...
1,350
First off, I am not a Siemens guy. I am trying to help a customer who bought an older machine with Siemens equipment in it. So far I have had no...
3,633
