plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old March 23rd, 2009, 04:47 AM   #1
ss4884
India
ss4884 is offline
INT to Real Datatype Conversion
can anyone help me out by guiding me how to perform INT to REAL Conversion..Pls It urgent
Old March 23rd, 2009, 04:50 AM   #2
bkottaras
United States
bkottaras is offline
Quote:
Originally Posted by ss4884 View Post
Most PLCs have a build in function block of sorts that will do that for you.
Not sure if you have read the help files or the manual but it is in there, give it a try.
Old March 23rd, 2009, 05:05 AM   #3
ss4884
India
ss4884 is offline
I tried but i didnt find any in siemens we have some standard instruction to do so but i didnt find the same in control logix. can you please help me out with some other suggestion
Old March 23rd, 2009, 05:08 AM   #4
OZEE
United States
OZEE is offline
What PLC? Every PLC does it differently...
Have you just tried a copy from your int into the new real??
Old March 23rd, 2009, 05:45 AM   #5
L D[AR2,P#0.0]
Supporting Member
United Kingdom
L D[AR2,P#0.0] is offline
If it's Siemens S7-300, you have to convert INT to DINT, then DINT to REAL.
Old March 23rd, 2009, 06:12 AM   #6
speedcat
Egypt
speedcat is offline
I Made It On s7-200 U Have To Convert It From INT TO DINT Then To Real ,You Will Find This Instrctions In ''Convert'',Put In Your Mind To Display Number Eventually As A Floating Point Wherever You Display It Status Chart,Scada Software..etc
Old March 23rd, 2009, 09:18 AM   #7
bernie_carlton
United States
bernie_carlton is offline
bernie_carlton's Avatar
SS4884 - the MOV command moves the VALUE from the Source to the Destination. Thus with an INT Source and a REAL Destination you will perform the operation you requested.
__________________
Controlling outputs is the PLC's way of getting its inputs to change.
www.thePLCguy.com
Old March 23rd, 2009, 09:31 AM   #8
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
Quote:
Sorry Bernie. But MOVE merely moves the content in a bitwise manner. There is no conversion.
In STL you write:
L "int_val"
ITD // convert to double-integer
DTR // Convert to real
T "real_val"
In LAD/FBD there are the blocks I_DI and DI_R.
Unfortunately they require that the result is stored in an intermediary address. So it is 'neater' in STL.
__________________
Jesper
Old March 23rd, 2009, 09:38 AM   #9
bernie_carlton
United States
jesperMP - no, COPy is the bitwise mover that you are thinking of. MOV interprets the value of the source and creates that value (as close as possible) in the destination.
I may have not made this clear. based on SS4884's last post it appears he is trying to sent an INT to a REAL in ControlLogix. It is for that platform that I made my staatement.
__________________
www.thePLCguy.com
Old March 23rd, 2009, 09:51 AM   #10
bkottaras
United States
Bernie is right.
In CLX all you need to do is MOV the (integer value) which will be the SOURCe to a (real value) which will be the DESTINATION.
No additional conversion is needed, CLX does it automatically.
Old March 23rd, 2009, 09:56 AM   #11
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
Reading this again, I am not certain if he used to work with CLX and is now working with S7, or it is is vice-versa. I just love it when someone post so ambigously.
__________________
Jesper
Old March 23rd, 2009, 10:49 AM   #12
OZEE
United States
OZEE is offline
Quote:
That's the deal -- he hasn't told us!!
Old March 24th, 2009, 01:22 AM   #13
ss4884
India
ss4884 is offline
Thanks bernie i tried as you suggested,It works
Old March 24th, 2009, 05:05 AM   #14
Kakka
India
Kakka is offline
Try this
In siemens..there is no direct conversion methods..but you have STL commands like ITD - Integer to Double
and DTR - Double to Real
Old March 24th, 2009, 06:55 AM   #15
bernie_carlton
United States
I guess that's an indirect answer to our 'which platform' question.
__________________
www.thePLCguy.com
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Confused "again" S7 indirect Thim LIVE PLC Questions And Answers 17 July 22nd, 2008 04:47 PM
Step7 INT to REAL conversion Levanteri LIVE PLC Questions And Answers 3 February 14th, 2008 11:49 AM
Not able to understand this S7-code drspanda LIVE PLC Questions And Answers 8 November 13th, 2007 12:06 PM
Ideas needed for Siemens S7 program tesalmin LIVE PLC Questions And Answers 12 March 4th, 2004 12:40 PM
Ab SLC FLOAT to Double Int Conversion wirehead LIVE PLC Questions And Answers 10 March 29th, 2003 09:56 AM
