PowerFlex 700 VC Stop Mode
rleon
Aug 2008
Baires
129
Hi:
I have configured in my PFlex the Stop Mode parameters as Fast Brake, it means:
[Stop/Brk Mode A], parameter 155 is Fast Brake and
[Stop/Brk Mode B], parameter 156 is Fast Brake
When I stop the drive trough digital input (the stop button is in the digital input configured as Stop-CF), in the HIM display shows the message "Fast Braking" and then, when the motor is near to stop, shows "DC Braking" and then stop completely. The stopping is very fast, about 2 or 3 seconds. At the moment, all is OK.
But when I send a Stop command via DeviceNet the HIM display only shows the message "Stop asserted" and the motor finally stops, but like it has a ramp, because the braking takes about 10 seconds to stop (I have Decel Time in 5 secs). Why the devicenet stop command not make a fast braking?
In ControlLogix I programmed The stop command with Latch until the "Active" bit is OFF. When the active bit if OFF, the stop commad Unlatch. I tried to retain the stop for more time (with a delay timer),but is the same ramp to stop and "Fast braking" message is never shown in the HIM.
Any idea?
Thanks!
Good evening; im working with a PowerFlex700 and i need to e-stop the drive in case of a Communication Failure. The PF700 is connected to a...
5,659
Hi: How can I make an emrgency Stop to a PowerFlex 700? I just have the emergency button in plantnear the motor (not using a safety relay) and I...
7,350
I've got a Powerflex 700 that doesn't like to get going in the mornings. This motor will run anywhere from 30 seconds to 5 minutes before it just...
154
Looking for some assistance. I am very familiar with Yaskawa VFDs, but not so much with AB VFDs. I am working on some hardwired AB PowerFlex 700...
127
Can someone with Drive Executive please save me a printout of the parameters for this drive in this file. I'm in a bind and would greatly...
362
