This is less of a PLC question and more an AutoCad Electrical Question
Mar 2009
oakville, ontario
88
I don't know if any of you guys here use that program for designing your wiring diagrams and power and control circuits ect, but i do - the question i have is this:
When your inserting a component into your drawing -the catalog that the software comes with only lists AB - SQD - EATON - and SIEMENS stuff. Now you can manually enter in new component data from the spec sheets of the items you select for your project - but i was wondering if there was any place you could download add-ons for the catalog? for all the other major hardware suppliers out there?
You have to go to Control Panel - Add or Remove Programs, then click on AutoCAD Electrical. This should bring up a screen that allows you to modify the installation and add new manufacturer databases. I don't remember the exact procedure, but it's pretty easy.
I know this can be done, but I can't get the router config right. My goal is to physically connect(using an ethernet cable) a device(PLC, RTU...
1,010
Hi, I have a compact battery powered home robot mower for fun project and am looking at basically only putting a remote I/O unit in the battery...
1,060
I am sure this has been talked about before but searching there is a ton of other things that come up... I have a customer thats installing 16...
18
7,141
Hello Gentlemen, I've just registered and this will be my first post :). I am still a beginner in PLCs especially in communication...
1,150
Looking for some help. I posted this on the Ubiquiti forum: Just joined the community, please be patient with me as I have, being kind with...
28
6,431
