plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old April 1st, 2009, 01:06 PM   #1
muzikant5
Canada
muzikant5 is offline
What version of SLC500
Hi
Can someone explain to me how the memory size limits the size of your program. For example an SLC5/01 has 1K of memory, how many rungs of program would that limit me to, or does it limit the number of Inputs and Outputs I use. If I want to control 12 outputs and 6 inputs, what kind of memory should I have at least and maybe even some spare memory in case I want to expand my program in the future. What's the minimum memory I should go with, 4k, 16k, 32k...
Also is it better to buy a TRIAC output card with SLC500 since I'll have to control coils which operate at 115VAC, or is it better that I use a DC Output card and have Solid State Relays. What's better in terms of money and life expectancy.
What's would I need when putting a SLC500 together, I'm assuming a Power Supply, CPU, Input, Output card. Correct me if I'm missing something.
And final question is what kind of cable is used to communicate with SLC500, is it Ethernet based, and how complicated is it to set up communication with the computer.
I know some of my questions might sound stupid, but I'm really new to PLCs and I would greatly appreciate all the available help and advice I can get from you guys. Thanks for your help in advance.
Old April 1st, 2009, 02:16 PM   #2
mgvol
United States
mgvol is offline
mgvol's Avatar
Try the selection guide at the link. Everything you need to know about SLC hardware and capabilities.
http://literature.rockwellautomation...g001_-en-p.pdf
Old April 1st, 2009, 03:44 PM   #3
muzikant5
Canada
Hi mgvol thanks for the link. I would still like an opinion from someone who actually used this PLC in field. For example I know that TRIAC output cards have some leakage current, and since I'm planning on controlling AC coils on directional valves that are 4W, 115VAC so current required to turn on these coils is fairly small. Is it better to use a Solid State relay maybe but even they have leakge currents. I won't to stay away from mechanical relays because they have moving parts and won't last maybe a month.
Also what software do I need to communicate with SLC500.
I'm assuming I need RSLogix 500 and RSlinx. Do I need a 1747-PIC cable also.
THanks for the help.
Old April 1st, 2009, 06:20 PM   #4
plc noob
United States
plc noob is offline
plc noob's Avatar
Smile
This is what we use http://www.ab.com/industrialcontrols...ys/700-hl.html
You will notice that they have a built in shunt for leakage current.
You can get these in solid state relay or mechanical and they still act as interposing relays.
This is the way to go because if a coil shorts,Field wiring damaged,etc the expensive output card is protected all you have to do is fix the field problem and replace a $5.00 relay vs. destroying a card that costs several hundred dollars.
Old April 1st, 2009, 09:30 PM   #5
muzikant5
Canada
Hi
Thanks for the reply. Would a solid state relay used with a dc output card be the same? I mean DC output card would be isolated from the coil with the relay.
Old April 2nd, 2009, 06:52 AM   #6
mgvol
United States
mgvol is offline
mgvol's Avatar
Regarding software & cables:
Yes, you will need RSLogix500 and RSLinx Lite (comes with Logix500). As far as cables go, that depends upon which CPU you go with. The 5/01 and 5/02 CPU's only have 1 comm port - an RJ45 connector that is DH-485 protocol. If your PC has a serial port, you would use the 1747-PIC; if all you have are USB ports, use 1747-UIC with a 1747-C13 cable. The 5/03 CPU also has the RJ-45 port for DH-485, so the cables mentioned above will work. The 5/03 also has a DB-9 serial port, that is default configured for RS-232 DF1 - a 1747-CP3 or any null-modem serial cable will work for this port.
The 5/04 CPU has a DH+ port, as well as the DB-9 port like the 5/03. For the DB-9, see the cable recommendations above; for DH+ you will need either a 1784-PCMK card for your laptop or a 1784-U2DHP USB to DH+ converter cable.
Finally, the 5/05 CPU has ports identical to the 5/03 (RJ-45 and a DB-9), but the RJ-45 port on the 5/05 is ethernet. For the ethernet port, use a CAT 5 crossover cable or a regular CAT 5 patch cable if you are using an ethernet switch or hub. The serial port uses the same cables as the 5/03 and 5/04.
Old April 2nd, 2009, 09:27 AM   #7
Mickey
United States
Mickey is offline
Mickey's Avatar
mgvol,
I'm saving this for future posting ( if you don't mind).
This question comes up a lot.
__________________
Mickey
If you want happiness for an hour-take a nap. If you want happiness for a day-go fishing. If you want happiness for a month-getmarried. If you want happiness for a year-inherit a fortune. If you want happiness for a lifetime-help someone else.
----- Chinese Proverb
Old April 2nd, 2009, 01:36 PM   #8
muzikant5
Canada
Thanks for the reply guys it really clarified some questions for me. If someone could briefly explain how the PLC memory limits you I would appreciate that very much.
And another question off topic, any suggestions on how to control a Timer Preset value from a potentiometer or some sort of a switch. Would my only option be to go with analog input or I can manage to do it somehow with digital input.
Thanks for the help.
Old April 2nd, 2009, 01:43 PM   #9
plc noob
United States
plc noob is offline
plc noob's Avatar
Smile
Well you really can't say with x amount of memory you can do x amount of rungs,xic,xio,ote,etc
Long story short it depends
It depends on how you structure and assemble your program.
An example is unused timers.Even if you have a timer element created in a timer dta file and you don't use it in your logic it still consumes 3 words of memory.
It is possible to run an entire machine in 2 or 3 rungs using sequencers but i would not recommend it.
Best thing is to get some idea of the program size in i/o and complexity before purchasing a processor
Old April 2nd, 2009, 03:00 PM   #10
muzikant5
Canada
Ok thanks for the reply plc_noob
Lets say I'll have 4 timers, 3 outputs, 2 inputs (digital)
How much memory would be sufficient for this type of program
Old April 2nd, 2009, 03:11 PM   #11
Mickey
United States
Mickey is offline
Mickey's Avatar
See appendix C of SLC500 instruction set manual below.
http://literature.rockwellautomation...m001_-en-p.pdf
__________________
Mickey
Old April 2nd, 2009, 03:11 PM   #12
hd_coop
United States
hd_coop is offline
hd_coop's Avatar
I don't believe you could find a PLC which didn't have enough memory for 2 inputs, 3 outputs and 4 timers.
Old April 2nd, 2009, 03:20 PM   #13
PLCMentor
United States
PLCMentor is offline
PLCMentor's Avatar
Hopefully you are reading the manual section that Mickey posted. What I dont think you are getting is that each and every instruction and data register created uses a certain amount of memory. Add up your timers, contacts, outputs, etc, then add up the data elements you will need with them and use the table to determine memory use. I can say that most anyone here wouldn't look at the book for the list you gave because there isnt a SLC out there that couldnt handle that. No reason to look it up for that.
To get a Pot value in the PLC you need analog. Discretes are just 1's and 0's. You might be able to have a group of set preset time periods that can be associated with some switches to acheive this without the pot.
Russell
__________________
Russell White, P.E.
Automation Technologies, Inc.
PLCMentor.com
Old April 2nd, 2009, 04:37 PM   #14
Ken Moore
United States
Ken Moore is offline
Ken Moore's Avatar
You could use a BCD wheel, hardwired digital inputs. You will need 4 discrete inputs for each digit of the BCD wheel, so a 4 digit number will require 16 inputs. You would be limited to integer values.
Then in the PLC you convert the BCD to binary and move it to a timer preset.
ken
__________________
"To give real service you must add something that cannot be bought or measured with money; and that is sincerity and integrity."
- Donald A. Adams
Old April 2nd, 2009, 04:40 PM   #15
Ken Moore
United States
Ken Moore's Avatar
For the small program you are talking about, a "smart" relay would be sufficient.
Can't do any math, but for straight ladder logic they work great for small non-critical applications.
You could change timer presets from the LCD screen.
Something like this: http://www.factorymation.com/s.nl/sc.2/category.22/.f
__________________
- Donald A. Adams
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Version Problem for Rockwell E3 module Eric Le Yin LIVE PLC Questions And Answers 4 January 22nd, 2009 01:05 AM
rsview32, using newer version of works editor with older version of runtime diat150 LIVE PLC Questions And Answers 7 February 11th, 2008 12:27 PM
Lastest Version OS on Slc500 cotang LIVE PLC Questions And Answers 4 August 29th, 2006 11:18 AM
Downgrade Intouch Project Version alpha98 LIVE PLC Questions And Answers 16 March 21st, 2006 09:46 AM
Proworx Demo Vs. Full Version CONTROLTESTGUY LIVE PLC Questions And Answers 2 January 25th, 2006 01:45 PM
