This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: May 2009
Using parts of arrays in STEP7
Hey all!
I am developing a general function block that will read quite some data from a PROFIBUS slave. This data is received with a length of 240 bytes at most at a time, but I need to save a lot more data than that. The data is received in a 241 byte long record. Now I've created a DB using SFC22 (CREAT_DB), and I want to put all the data in that DB, byte for byte. The data is variable though, it may not always be 240 byte. I was thinking to save byte 7-n (n being the last byte of data) into the newly created DB, and then when reading the data from the next station (got a bunch of stations), just put the data from the second station after the first, and so on, with a couple of variables to keep track of what data belongs to what station. How do I do to accomplish this? I was thinking about SFC20 (BLKMOV), but it only takes a whole array as parameter and puts it in the beginning of the destination, not with an offset, as is needed in my function block. Basically, I want to save a portion of an array into a second array, and fill this second array with more and more data from different stations. |
#2 |
Supporting Member
![]() Join Date: Nov 2006
You can create your own source and destination any pointers and pass them to SFC20
Here's an example: Code:
FUNCTION FC200 : VOID TITLE =transfer bytes between db's //Transfer bytes of data between data blocks using SFC20 // VAR_INPUT dbSourceDB : BLOCK_DB ; //source data block iSourceDBNumber : INT ; //source data block number (set to zero to use above) iSourceByteOffset : INT ; //source data byte offset dbDestinationDB : BLOCK_DB ; //destination data block iDestinationDBNumber : INT ; //destination data block number (set to zero to use above) iDestinationByteOffset : INT ; //destination data byte offset iNumberOfBytes : INT ; //number of bytes to xfer END_VAR VAR_OUTPUT iMoveResult : INT ; //result from block xfer SFC20 END_VAR VAR_TEMP pSourceDB : ANY ; pDestDB : ANY ; END_VAR BEGIN NETWORK TITLE =any pointer for source LAR1 P##pSourceDB; L W#16#1002; //specify ANY pointer, type 02 = BYTE T W [AR1,P#0.0]; L #iNumberOfBytes; //number of bytes to transfer T W [AR1,P#2.0]; L 0; L #iSourceDBNumber; //if iSourceDBNumber = 0 then ==I ; // opn db and use DBNO to find number JC opnS; // else use iSourceDBNumber JU trnS; opnS: OPN #dbSourceDB; L DBNO; //data block to use trnS: T W [AR1,P#4.0]; L DW#16#84000000; //global data block for area pointer L #iSourceByteOffset; SLD 3; +D ; T D [AR1,P#6.0]; //start of data block NETWORK TITLE =any pointer for destination LAR1 P##pDestDB; L W#16#1002; //specify ANY pointer, type 02 = BYTE T W [AR1,P#0.0]; L #iNumberOfBytes; //number of bytes to transfer T W [AR1,P#2.0]; L 0; L #iDestinationDBNumber; //if iDestinationDBNumber = 0 then ==I ; // opn db and use DBNO to find number JC opnD; // else use iDestinationDBNumber JU trnD; opnD: OPN #dbDestinationDB; L DBNO; //data block to use trnD: T W [AR1,P#4.0]; L DW#16#84000000; //global data block for area pointer L #iDestinationByteOffset; SLD 3; +D ; T D [AR1,P#6.0]; //start of data block NETWORK TITLE =copy data CALL "BLKMOV" ( SRCBLK := #pSourceDB, RET_VAL := #iMoveResult, DSTBLK := #pDestDB); NOP 0; NETWORK TITLE =Make sure the ENO shows the BLKMOV result A BR; // BR is 1 for no error JC ok; JU nok; ok: SET ; // Make the ENO high SAVE ; JU end; nok: CLR ; // Make the ENO low SAVE ; end: NOP 0; END_FUNCTION Last edited by L D[AR2,P#0.0]; May 7th, 2009 at 09:32 AM. Reason: added example |
#3 |
Thanks, this was just what I was looking for, excellent!
Two more questions though; I'm not very used to working with pointers and DB's, so how do I transfer a whole array to a temporary DB? The DB could be taken as an input variable to the FB if it makes it easier. Also, I have a problem passing parameters to this function. In my block, I got a few Block_DB as input parameters, but Step7 won't accept me using these as input parameters to this function. E.g. one input parameter is called DBL1, and is of type Block_DB. How do I get this to fit as an input parameter to this function? Thanks |
#4 |
Just so that I understand what you want to achieve:
How is the number of bytes to transfer determined ? Does the number of bytes vary freely at runtime, or is it following some kind of fixed structure ?
__________________
Jesper
#5 |
![]() Join Date: Mar 2008
Hi LD,
Was checking out your code, and had a small question. After a quick check, i see you have an Inputvariable of type DB_block, then u only use it to open the block and get the number out of it, what is the advantage of this? Is there a big difference with just having a integer as input, then load this integer to a temp(type word) and opn the db, or in this case to transfer the value in to the anypointer directly. Or isn't there any difference, and just to make the function work for any case since, you also program the jump "trnd" Thx |
#6 |
@JesperMP: The number of bytes can be anything between 0-240 and varies freely. I get the number of bytes by reading a record using SFC59
#7 |
![]() Join Date: Jun 2006
why are you transferring to a temp DB? Is it because you want to use the values in a local area.
I ave done this by transferring into local temp words using SFC20, better than creating a DB if that's your purpose. |
#8 |
Since this function LD wrote requires two DB's, I thought I had to put them in DB's?
#9 | |
Quote:
If on the other hand, you just need access to the data in the block where the transfer is taking place (as a convenient common area), then perhaps transferring into local temp flags is more efficient, both for memory and scan. |
#10 |
I need to access the destination DB from otherwere in the program, but the source should only be accessed in the FB that the transfer is conducted.
This block is to read the data, and put in in DB's, that other function(block)s are accessing. How do I use local temp flags? |
#11 |
Supporting Member
Robert - the code I posted is a function that shows you how to create an any pointer at run time and pass this to SFC20 to perform a block move. You should use this principle for creating your own code.
#12 | |
Supporting Member
Quote:
#13 |
Thx LD
So if i understand well, when you have a fixed DB it is better to use the datatype BLOCK_DB, then you can use Cross Ref If the DB is variable through the program it would be better to use the integer as variable. Thx |
#14 | |
Supporting Member
Quote:
#15 |
Supporting Member
... and if you want to do it in a FB, the coding is very different:
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Boolean arrays!! | Siri Singamneni | LIVE PLC Questions And Answers | 10 | December 15th, 2008 10:48 PM |
| Now we're getting somewhere, Step7 / 313C | dahnuguy | LIVE PLC Questions And Answers | 20 | November 13th, 2008 02:13 AM |
| Step7 MicroWin integration with Step7 | adfox | LIVE PLC Questions And Answers | 6 | September 1st, 2006 05:24 AM |
| A pitfall upgrading STEP7. | JesperMP | LIVE PLC Questions And Answers | 2 | May 31st, 2005 01:29 AM |
| step7 | walters | LIVE PLC Questions And Answers | 4 | April 14th, 2005 04:49 AM |
