OPC test Client cannot connec to RSLinx Proffesional
Eric Le Yin
Oct 2008
Rawang
I am newbie to OPC.
I have a new OPC test Client which is running on FMC application supplied in package from Thermo Fished Scientific.
The problem i have now is i cannot connect to the RSLinx OPC server on local computer which i had install the RSlinx Proffesional using the Thermo OPC test client.
I can connect and get tags from RSlinx Server using the RSI OPC test client.
What could i do or check to established the connection between the Thermo OPC Test Client to the RSLinx professional server locally.
My RSLinx Professional is 2.43.00
RSI OPC test client :
OPC Data Access 2.0 Client
Version : 2.3.11
Thermo OPC test Client is
Version 2.15.0.13.2
File Version : 1.0.0.1
OPC test Client MFC application
Hello all, I have a compact Logix CPU communication with Rslinx. Scada is Wincc is pulling tags from RSLINX OPC server. It is a working machine...
1,317
I'm trying to read registers from a SLC5/05 using RSI OPC Test Client. Seems I can get everything to work except the inputs and outputs. In...
5,254
Alright, here is what I know. In the lab we are building a new OSIsoft PI system and need to inject some real life data into the machines for...
11,727
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
224
I know nothing about simaticnet OPC server. I do know Kepware. I would only ever scale raw to engineering in the PLC, but it is possible to scale...
217
