plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old May 27th, 2009, 04:05 AM   #1
gsmoh2000
Egypt
gsmoh2000 is offline
Post check firmware version of CNBR
Dear all
i have a problem that is i lose the communication between Controller and I/O , when i check the PLC , i have reduendency CPU , the 1st i found on it Primary with QS , and the second is Sync (QS) but CNBR /E cards having red colors and not working , i make power reset for these cards and it work now healthy , i check rockwell automation website and i find that firmware version of CNBR cards is 10.004 this problem occur every 70.96 days so i try to get firmware version of these cards to check but i fail so please if you have solution for this problem please send me and how can i check the firmware version of CNBR without effecting on process
Old May 27th, 2009, 05:53 AM   #2
rdrast
United States
rdrast is offline
rdrast's Avatar
RSLinx -> RSWho -> Navigate to the ControlNet Bridge, Right click, "Device Properties".
The Firmware revision will show in the dialog box.
You can also check if ONLINE with RSLogix, by again, navigating to the module, opening up it's properties box, and going to the "Module Info" tab.
All of our 'standard' CNB/E's are at 11.2 (which is actually 11.002 by Rockwell's odd versioning system). Our CN2/B's are at 20.9 (20.009).
__________________
How to ask questions the SMART Way!
Look First, Ask Second!
Old May 27th, 2009, 01:05 PM   #3
Ken Roach
United States
Ken Roach is offline
Ken Roach's Avatar
Using RSLinx Classic, browse to the 1756-CNB(R) module, right-click and select Module Properties. This will show you the current version of firmware in the module.
If your connection is using Ethernet, select the 1756-CNB(R) when you see it in the 1756 Chassis.
If your connection is using ControlNet, select the 1756-CNB(R) directly on the ControlNet network.
A browse can fail if you browse through a module and "loop around"
You should also be able to use the embedded web page in a 1756-ENBT/EN2T module to perform a chassis browse that will list the current firmware.
If this is an important system, I very strongly recommend engaging Rockwell Automation directly to assist your troubleshooting.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Fanuc 9030 firmware upgrade problem rainbow_elec LIVE PLC Questions And Answers 2 August 30th, 2008 08:46 AM
Controllogix V16.50 Firmware problem Graeme LIVE PLC Questions And Answers 9 April 1st, 2008 11:55 AM
Panel View plus firmware idresu LIVE PLC Questions And Answers 0 March 10th, 2008 10:48 PM
rsview32, using newer version of works editor with older version of runtime diat150 LIVE PLC Questions And Answers 7 February 11th, 2008 12:27 PM
Panelview boot version VS firmware version elperepat LIVE PLC Questions And Answers 0 October 20th, 2003 10:53 AM
