plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old July 8th, 2009, 04:38 PM   #1
MajorFault
United States
MajorFault is offline
MajorFault's Avatar
Extracting Tag Values from ControlLogix
Can anyone tell me how to extract/export tag "values" from a ControlLogix processor? I have used the Tag Upload Download Tool and the Export/Tags and Logic Comments. As most of you know, this exports a list of tags but not their values.
I have a a STRING with an array length of 1000. I am collecting data from various tags in the program, putting this data together, adding a time/date stamp and storing this in one string. I am taking about 300 samples a day. Every two or three days, I would like to extract this data to a CSV file or something I can open in Excel. I did not want to create a DDE/OPC link in a spreadsheet since we are talking about 1000 tags.
Any ideas?
Old July 8th, 2009, 05:17 PM   #2
Paully's5.0
United States
Paully's5.0 is offline
What HMI software are you using, if any?
Old July 8th, 2009, 05:33 PM   #3
MajorFault
United States
MajorFault's Avatar
I'm not using any. I was looking for a (simple)way to do it through OPC server with RSLinx Classic.
I do use PanelBuilder 32, RSView and WonderWare here at our facility. So I guess I could build an app to collect data from those tags.
Just seems like there should be a simple way to read this tag data and put it in a spreadsheet.
Old July 8th, 2009, 05:45 PM   #4
WildeKurt
United States
WildeKurt is offline
I've used Ingear Active X control available from Software Toolbox (http://www.ingearactivex.com/). It does not require RsLinx which is nice. You can use it in VB or VBA as part of an Excel spreadsheet.
Old July 8th, 2009, 06:14 PM   #5
Paully's5.0
United States
I was asking about the HMI because I've setup RSView32 before and had it log data to a SQL express database.
Once in the database you can then run the dts wizard to export the data to an excel file.
Free, not the easiest, but free.
Cost is where the issue is, you can read OPC tags fairly easily, but when it comes to pushing those values to a database or other you'll have to pay for the software to do that.
I'm currently evaluating FactorySQL this purpose.
Old July 9th, 2009, 10:36 AM   #6
WildeKurt
United States
I've looked into FactorySQL a bit myself and liked the product. I used it as part of a proposal to collect production data. Sadly, due to the economy the project was put on hold. If business picks up, we'll probably go ahead with it.
Old July 9th, 2009, 10:45 AM   #7
dougrb
United States
dougrb is offline
In what way did the tag upload download tool not work for you?
Old July 9th, 2009, 10:58 AM   #8
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
You could use VBA within MS Excel to read the data in small chunks so that the DDE/OPC connection does not overwhelm the CPU.
I have only done this with a SLC using borrowed code, but I am sure the concept is similar with controllogix. I have a SLC that logs events to several files which I read with a macro in excel only when the file is opened or the "Update" button is clicked. It works quite well, even though my SLC is connected via a NET-ENI module.
That is why I did what I did, after finding out that I could only read about 120 integers at a time without errors, the DDE link was not the way to go, since my log file is 1024 elements long and each element has a float and two integers.
My vba code looks like this:
Code:
Sub update()
'open dde link
Dim data
RSIchan = DDEInitiate("RSLinx", "SP_ROBOT")
'Handle first column: Timestamp
'First timestammp data file is F74
data = DDERequest(RSIchan, "F74:0,L32,C1")
Worksheets("raw data").Range("A2:A33").Value = data
data = DDERequest(RSIchan, "F74:32,L32,C1")
Worksheets("raw data").Range("A34:A65").Value = data
data = DDERequest(RSIchan, "F74:64,L32,C1")
Worksheets("raw data").Range("A66:A97").Value = data
data = DDERequest(RSIchan, "F74:96,L32,C1")
Worksheets("raw data").Range("A98:A129").Value = data
data = DDERequest(RSIchan, "F74:128,L32,C1")
Worksheets("raw data").Range("A130:A161").Value = data
data = DDERequest(RSIchan, "F74:160,L32,C1")
Worksheets("raw data").Range("A162:A193").Value = data
data = DDERequest(RSIchan, "F74:192,L32,C1")
Worksheets("raw data").Range("A194:A225").Value = data
data = DDERequest(RSIchan, "F74:224,L32,C1")
Worksheets("raw data").Range("A226:A257").Value = data
'Next timestammp data file is F75
data = DDERequest(RSIchan, "F75:0,L32,C1")
Worksheets("raw data").Range("A258:A289").Value = data
data = DDERequest(RSIchan, "F75:32,L32,C1")
Worksheets("raw data").Range("A290:A321").Value = data
data = DDERequest(RSIchan, "F75:64,L32,C1")
Worksheets("raw data").Range("A322:A353").Value = data
data = DDERequest(RSIchan, "F75:96,L32,C1")
Worksheets("raw data").Range("A354:A385").Value = data
data = DDERequest(RSIchan, "F75:128,L32,C1")
Worksheets("raw data").Range("A386:A417").Value = data
data = DDERequest(RSIchan, "F75:160,L32,C1")
Worksheets("raw data").Range("A418:A449").Value = data
data = DDERequest(RSIchan, "F75:192,L32,C1")
Worksheets("raw data").Range("A450:A481").Value = data
data = DDERequest(RSIchan, "F75:224,L32,C1")
Worksheets("raw data").Range("A482:A513").Value = data
'Next timestammp data file is F76
data = DDERequest(RSIchan, "F76:0,L32,C1")
Worksheets("raw data").Range("A514:A545").Value = data
data = DDERequest(RSIchan, "F76:32,L32,C1")
Worksheets("raw data").Range("A546:A577").Value = data
data = DDERequest(RSIchan, "F76:64,L32,C1")
Worksheets("raw data").Range("A578:A609").Value = data
data = DDERequest(RSIchan, "F76:96,L32,C1")
Worksheets("raw data").Range("A610:A641").Value = data
data = DDERequest(RSIchan, "F76:128,L32,C1")
Worksheets("raw data").Range("A642:A673").Value = data
data = DDERequest(RSIchan, "F76:160,L32,C1")
Worksheets("raw data").Range("A674:A705").Value = data
data = DDERequest(RSIchan, "F76:192,L32,C1")
Worksheets("raw data").Range("A706:A737").Value = data
data = DDERequest(RSIchan, "F76:224,L32,C1")
Worksheets("raw data").Range("A738:A769").Value = data
'Next timestammp data file is F77
data = DDERequest(RSIchan, "F77:0,L32,C1")
Worksheets("raw data").Range("A770:A801").Value = data
data = DDERequest(RSIchan, "F77:32,L32,C1")
Worksheets("raw data").Range("A802:A833").Value = data
data = DDERequest(RSIchan, "F77:64,L32,C1")
Worksheets("raw data").Range("A834:A865").Value = data
data = DDERequest(RSIchan, "F77:96,L32,C1")
Worksheets("raw data").Range("A866:A897").Value = data
data = DDERequest(RSIchan, "F77:128,L32,C1")
Worksheets("raw data").Range("A898:A929").Value = data
data = DDERequest(RSIchan, "F77:160,L32,C1")
Worksheets("raw data").Range("A930:A961").Value = data
data = DDERequest(RSIchan, "F77:192,L32,C1")
Worksheets("raw data").Range("A962:A993").Value = data
data = DDERequest(RSIchan, "F77:224,L32,C1")
Worksheets("raw data").Range("A994:A1025").Value = data
'Handle next column: Event Code
'First Event Code data file is N78
data = DDERequest(RSIchan, "N78:0,L64,C1")
Worksheets("raw data").Range("B2:B65").Value = data
data = DDERequest(RSIchan, "N78:64,L64,C1")
Worksheets("raw data").Range("B66:B129").Value = data
data = DDERequest(RSIchan, "N78:128,L64,C1")
Worksheets("raw data").Range("B130:B193").Value = data
data = DDERequest(RSIchan, "N78:192,L64,C1")
Worksheets("raw data").Range("B194:B257").Value = data
'Next Event Code data file is N79
data = DDERequest(RSIchan, "N79:0,L64,C1")
Worksheets("raw data").Range("B258:B321").Value = data
data = DDERequest(RSIchan, "N79:64,L64,C1")
Worksheets("raw data").Range("B322:B385").Value = data
data = DDERequest(RSIchan, "N79:128,L64,C1")
Worksheets("raw data").Range("B386:B449").Value = data
data = DDERequest(RSIchan, "N79:192,L64,C1")
Worksheets("raw data").Range("B450:B513").Value = data
'Next Event Code data file is N80
data = DDERequest(RSIchan, "N80:0,L64,C1")
Worksheets("raw data").Range("B514:B577").Value = data
data = DDERequest(RSIchan, "N80:64,L64,C1")
Worksheets("raw data").Range("B578:B641").Value = data
data = DDERequest(RSIchan, "N80:128,L64,C1")
Worksheets("raw data").Range("B642:B705").Value = data
data = DDERequest(RSIchan, "N80:192,L64,C1")
Worksheets("raw data").Range("B706:B769").Value = data
'Next Event Code data file is N81
data = DDERequest(RSIchan, "N81:0,L64,C1")
Worksheets("raw data").Range("B770:B833").Value = data
data = DDERequest(RSIchan, "N81:64,L64,C1")
Worksheets("raw data").Range("B834:B897").Value = data
data = DDERequest(RSIchan, "N81:128,L64,C1")
Worksheets("raw data").Range("B898:B961").Value = data
data = DDERequest(RSIchan, "N81:192,L64,C1")
Worksheets("raw data").Range("B962:B1025").Value = data
'Handle next column: Event Data
'First Event Data file is N82
data = DDERequest(RSIchan, "N82:0,L64,C1")
Worksheets("raw data").Range("C2:C65").Value = data
data = DDERequest(RSIchan, "N82:64,L64,C1")
Worksheets("raw data").Range("C66:C129").Value = data
data = DDERequest(RSIchan, "N82:128,L64,C1")
Worksheets("raw data").Range("C130:C193").Value = data
data = DDERequest(RSIchan, "N82:192,L64,C1")
Worksheets("raw data").Range("C194:C257").Value = data
'First Event Data file is N83
data = DDERequest(RSIchan, "N83:0,L64,C1")
Worksheets("raw data").Range("C258:C321").Value = data
data = DDERequest(RSIchan, "N83:64,L64,C1")
Worksheets("raw data").Range("C322:C385").Value = data
data = DDERequest(RSIchan, "N83:128,L64,C1")
Worksheets("raw data").Range("C386:C449").Value = data
data = DDERequest(RSIchan, "N83:192,L64,C1")
Worksheets("raw data").Range("C450:C513").Value = data
'First Event Data file is N84
data = DDERequest(RSIchan, "N84:0,L64,C1")
Worksheets("raw data").Range("C514:C577").Value = data
data = DDERequest(RSIchan, "N84:64,L64,C1")
Worksheets("raw data").Range("C578:C641").Value = data
data = DDERequest(RSIchan, "N84:128,L64,C1")
Worksheets("raw data").Range("C642:C705").Value = data
data = DDERequest(RSIchan, "N84:192,L64,C1")
Worksheets("raw data").Range("C706:C769").Value = data
'First Event Data file is N85
data = DDERequest(RSIchan, "N85:0,L64,C1")
Worksheets("raw data").Range("C770:C833").Value = data
data = DDERequest(RSIchan, "N85:64,L64,C1")
Worksheets("raw data").Range("C834:C897").Value = data
data = DDERequest(RSIchan, "N85:128,L64,C1")
Worksheets("raw data").Range("C898:C961").Value = data
data = DDERequest(RSIchan, "N85:192,L64,C1")
Worksheets("raw data").Range("C962:C1025").Value = data
'close dde link
DDETerminate (RSIchan)
End Sub
__________________
It's not all the variables I am most concerned with, it's the undiscovered constants.
Old July 9th, 2009, 11:22 AM   #9
junior
United States
junior is offline
Scada_Dude had a good open source HMI, PVBrowser(http://pvbrowser.de/pvbrowser/index.php). Not sure if it supports contrologix though, but it's worth checking out.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
How to copy data in a tag to another tag in Controllogix cdmeieril LIVE PLC Questions And Answers 3 July 9th, 2008 05:13 PM
Retain Controller Data in an HMI tag (Allen-Bradley) Money4Nothing LIVE PLC Questions And Answers 16 July 19th, 2007 08:38 AM
Transferring tag values from one RSLogix5000 file to another. radfahrer LIVE PLC Questions And Answers 2 December 6th, 2006 05:09 PM
Downloading to ControlLogix without overwriting Tag values ihc LIVE PLC Questions And Answers 5 October 19th, 2006 04:51 PM
RSLogix5000 tag values jshiepe LIVE PLC Questions And Answers 3 August 30th, 2004 09:35 AM
