plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old July 16th, 2009, 10:19 AM   #1
ascot01
United States
ascot01 is offline
ascot01's Avatar
Need 0-10 vdc from 48 vdc
I need to benchtest a dc motor drive and the motor and need to fabricate a variable switch or rheostat to give the 0 - 10 vdc input for speed control.
My source voltage is 48 vdc.
I can use resistors to make voltage dividers and pushbuttons to step the voltage incrementally from 1 to 10 volts but I need a smooth sliding type switch like a pot or rheostat but cant figure out how to make it. I know there's something fundamental I'm missing here, it can't be that difficult.
Old July 16th, 2009, 11:32 AM   #2
eebads2391
United Kingdom
eebads2391 is offline
Step down transformer ? ?
It's output would be proportional to the input
Old July 16th, 2009, 11:50 AM   #3
Steve Bailey
United States
Steve Bailey is offline
Steve Bailey's Avatar
Connect a 38K fixed resistor in series with a 10K pot. Total current will be 1 mA. Power is 0.048 watt.
You could do the same with 19K fixed resistance and a 5K pot. In that case the current is 2 mA and the power is 0.096 watt.
This is basic Ohm's law stuff.
eebads2391, if you have a transformer that can step down a DC voltage, I suggest you apply for a patent.
Old July 16th, 2009, 11:50 AM   #4
leitmotif
United States
leitmotif is offline
I would use a reostat (potentiometer) off the 48 VDC.
Dan Bentler
Old July 16th, 2009, 11:54 AM   #5
CowDung
United States
CowDung is offline
CowDung's Avatar
Transformers are only good for AC...
Old July 16th, 2009, 12:12 PM   #6
ascot01
United States
ascot01 is offline
ascot01's Avatar
Thanks very much, I'll order those parts.
Old July 16th, 2009, 12:57 PM   #7
bernie_carlton
United States
bernie_carlton is offline
bernie_carlton's Avatar
These answers are neglecting the input impedence of the drive. Thoough if it is pretty high then the affect on the voltage divider would be negligible.
__________________
Controlling outputs is the PLC's way of getting its inputs to change.
www.thePLCguy.com
Old July 16th, 2009, 01:06 PM   #8
Steve Bailey
United States
I just realized that I should have asked whether or not the drive has terminals defined to connect a speed pot. It's such a common method of establishing a speed preset that it would be somewhat of a surprise if the drive isn't already set up for it.
If you can post a link to the user's manual for the drive, perhaps we can point out how to accomplish what you need to do.
Old July 16th, 2009, 03:13 PM   #9
leitmotif
United States
Forgot about that too. Some I have seen include the pot.
Dan Bentler
Old July 16th, 2009, 03:23 PM   #10
eebads2391
United Kingdom
I know , sorry, getting confused with something ive seen from the CB radio days that were sold to truck drivers
24 v dc in 12 dc out
Sorry for misleading comment
Old July 16th, 2009, 04:32 PM   #11
ascot01
United States
ascot01 is offline
ascot01's Avatar
Thanks for your help
Advanced Motion Controls
www.a-m-c.com
Brush Type PWM Servo Amplifier
model 120A10
i don't see a pot for manually adjusting the 0-10 input unless it's under the cover.
I uploaded spec sheets and 2 pictures.
Old July 16th, 2009, 05:27 PM   #12
rootboy
United States
rootboy is offline
rootboy's Avatar
I've done this in the past with just a battery, no need for the 48v supply.
A 1.5 volt battery will give you roughly 15% of your top speed. Two will give you 30%, and so on.
Here's a down-and-dirty 0 - 10 volt adjustable supply that uses only four parts.
http://media.photobucket.com/image/0...pson/0-10V.jpg
Or you can go for the voltage divider circuit - just two parts.
__________________
Just because you can doesn't mean that you should...
Old July 16th, 2009, 05:32 PM   #13
Steve Bailey
United States
Take a look at page G-18, the paragraph headed "Reference Potentiometer Wiring".
http://www.a-m-c.com/download/docume.../instnotes.pdf
This is a drive for a motion control system. It needs a +/- 10 vdc speed command to make full use of its capabilites. Positive speed command makes the motor turn in one direction. Reverse polarity to reverse direction.
Old July 16th, 2009, 07:25 PM   #14
leitmotif
United States
I think a little attention should go to what he wants the motor to drive ie conveyer or some servo type application.
SO what does the motor drive? What are your expectations?
What is HP of motor?
If he does not need servo performance why go with servo drive?
Have run (short bench test) small 1/4 HP 90 VDC permanent magnet motors off just a 9 V electronincs. Worked well.
Dan Bentler
Old July 16th, 2009, 07:35 PM   #15
ascot01
United States
ascot01 is offline
ascot01's Avatar
Thanks so much
Rootboy I'm not quite up to speed on the symbols..what is that triangle? A diode or gate maybe? Thanks for the drawing.
Steve thanks for the article I would've never recognized paragraph 3.7 as the answer. That looks like the easiest solution.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
DF1 Protocol and Command Set Reference Manual lazymonkeygod LIVE PLC Questions And Answers 10 January 21st, 2009 03:39 PM
seriesed 125VDC contacts to switch 250 VDC ?? leitmotif LIVE PLC Questions And Answers 4 December 17th, 2008 01:14 PM
AB Powerflex 400 Parameters andrewbe LIVE PLC Questions And Answers 62 September 24th, 2007 09:00 AM
I hope someone may find what's wrong... saucekorn69 LIVE PLC Questions And Answers 4 September 2nd, 2005 11:35 AM
RS232 Communication and 12 VDC power supply Lyndon LIVE PLC Questions And Answers 5 April 10th, 2003 07:55 AM
