![]() ![]() ![]() ![]() This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() ![]() Join Date: May 2004
Passing Global parameters in Factory Talk View Se
I have defined a global object, which when clicked on, opens a display. I have not been able to pass tag subtitutions to that display. The "Global Object Parameter Definitions are defined as;
#1 ChmbrWtrOk.n #2 DoorWtrOK.n #3 TranShldWtrOK.n #4 Mag1WtrOK.5 for chamber 5, else 1 #5 TransShld2WtrOK.n #6 Horiz #7 Vert #8 Screen Name #9 Turbo1_WtrOK.n #10 Turbo2_WtrOK.n #11 Mag1Running.n #12 HeaterCabB[x].Contactor_Closed #13 HeaterCabA[x].HV_Door_OK #14 HeaterCabA[x].HV_Backside_OK #15 HeaterCabA[x].Chamber_Interlocks_OK #16 HeaterCabA[x].TC_Limits_OK #17 HeaterCabB[x].Contactor_Closed (chamb 3 and 4, non 5 zone heaters) #18 HeaterCabA[x].Chamber_Interlocks_OK (chamb 3 and 4, non 5 zone heaters) #19 HeaterCabA[x].TC_Limits_OK (chamb 3 and 4, non 5 zone heaters) The parameters I need to pass to the reference object are defined as; displayName = #8; Display "Chamber Water" /T#1,#2,#3,#4,#5,#9,#10,#11, #12,#13,#14,#15,#16,#17,#18,#19 /X#6 /Y#7; One of the reference objects has it's Global Object Parameter values defined as; #1 [CIGSJ]ChmbrWtrOK.3 #2 [CIGSJ]DoorWtrOK.3 #3 [CIGSJ]TranShldWtrOK.3 #4 dummyTag1 #5 [CIGSJ]TranShld2WtrOK.3 #6 308 #7 70 #8 "Chamber 3" #9 [CIGSJ]Turbo1_WtrOK.3 #10 dummyTag2 #11 dummyTag3 #12 [CIGSJ]HeaterCabB[1].Contactor_Closed #13 dummyTag4 #14 dummyTag5 #15 [CIGSJ]HeaterCabA[1]Chamber_Interlocks_OK #16 [CIGSJ]HeaterCabA[1]TC_Limits_OK #17 [CIGSJ]HeaterCabB[2].Contactor_Closed #18 [CIGSJ]HeaterCabA[2]Chamber_Interlocks_OK #19 [CIGSJ]HeaterCabA[2]TC_Limits_OK When the reference oject is clicked on, instead of seeing the tags above diplay there state (OK or NOT OK) I get ERROR instead. The OK, NOT OK are displayed via a multistate indicator, one for each of the tags defined above. The dummyTag's above are placeholders, since each reference object has a unique configuration. I have also tried defining a parameter file, and passing the parameters with /Pfilename. This also did not work. I have read the Rockwell Knowledge base and found two patches that are supposed to fix this problem, but after installing the patches, the problems is still there. Does anyone know how to pass parameters to a display from a global object? |
Bookmarks |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Factory Talk View Se Retentive Value | enault | LIVE PLC Questions And Answers | 1 | February 3rd, 2009 12:06 PM |
Factory Talk View SE | SMOKE | LIVE PLC Questions And Answers | 4 | December 29th, 2008 06:51 AM |
Factory Talk View SE Client | kurt.brinker | LIVE PLC Questions And Answers | 3 | September 11th, 2008 09:11 AM |
Factory Talk View SE Trend | kurt.brinker | LIVE PLC Questions And Answers | 3 | April 14th, 2008 03:27 PM |
Upgrade to factory talk view se | kurt.brinker | LIVE PLC Questions And Answers | 2 | January 11th, 2008 02:37 PM |
