plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old October 13th, 2009, 05:43 PM   #1
csolo2117
United States
csolo2117 is offline
shrink wrap problem
Yes I have a copy of some ladder logic on a shrink wrapper, the shrink ring isn't working properly can anyone look at my copy of the logic and help RSlogix5000
Old October 13th, 2009, 06:04 PM   #2
Norml
United States
Norml is offline
The PLC logic is the last thing I would look at without first looking for bad connections, pitted relay contacts, thermocouple integrity etc. Sometimes just going online with the PLC and watching the I/O will point you in the right direction. (I'm assuming that it hasn't been done yet)
Old October 13th, 2009, 06:34 PM   #3
csolo2117
United States
shrink wrap ring
I have tried and checked all that which seem to be all normal
Old October 13th, 2009, 08:06 PM   #4
cjd1965
United Kingdom
cjd1965 is offline
I have to agree with Norml.
If it has ever worked ok and the PLC hasnt been changed then u need to look elsewhere. Of course monitoring the PLC may assist in doing that. Contact Rockwell/AB if u need software, or if u need a print out attached the file onto here and some kind soul will make u a pdf
Old October 14th, 2009, 07:12 AM   #5
Doylen
United States
Doylen is offline
Doylen's Avatar
The helping soul can be ME!
But, before anything else. I want to know who made the shrink wrapper.
It has built w/ RS5000 so I felt I might know who did. I'm end-user too and have shrink wrapper. IF PLC logic was never right 1st place, maybe it is time to fix once for all.
Typical my shrink wrapper problem;
The latching output of cylinder valve is sticking while the transfer push is active. In this case, I changed logic, so it doesn't interfere each other using sequential logics. Also, time to time, confusing TOF vs. TON vs. RTO timers conjuntion w/ transfer push delay. Well, even in this case, I had to change TOF to TON and make counter and RTO reset bit(Clear bit) use to re-arrange logics.
__________________
Doylen from Virginia
Does your supervisor knows you're helping others not your company?
Old October 14th, 2009, 07:30 AM   #6
Ned_Flanders
England
Ned_Flanders is offline
Ned_Flanders's Avatar
I am sorry, but I can't understand what you are saying!
OP's problem.
I work with a couple of shrinkwrappers. Robopac and Octopus.
The "Logic" is basically spilt into: Getting the pallet into and outof the machine and; The wrapping cycle.
Unless the thing is homemade and may have never worked properly, check Sensors, Cylinders, Slip rings, film drive (AC or DC, drive contactors etc. I really wouldn't touch the plc.
Perhaps if you post the exact fault it would be easier to help.
__________________
What do you mean "You're not in tomorrow?" D'oh!
Old October 14th, 2009, 06:52 PM   #7
Doylen
United States
Doylen is offline
Doylen's Avatar
Markie...Please look at the original post. It's not me asking questions. I am surely don't have problem.
The shrink wrappers, in the other hand, you are referring to pallet wrapper, such as robopac and octopus. I wasn't.
My wrapper is made by AMFA, and it packages 24 buns.
With 6 lanes of conveyor separates buns into 6 by 4 and plastic wrap comes down and seals on the side with wheels. Then sealed buns goes to platen device to make 4 stacks of 24 buns and push to another shrink wrapper. Then it will be transfer to packing machine and with 5th panel wrap around box will be formed and insert buns. After its sealed with glues and palletizer picks and place to pallets. Afterward, two stacked pallets will be wrapped again by Octopus and deliver to trucking lanes for shipment.
__________________
Old October 15th, 2009, 06:05 AM   #8
Ned_Flanders
England
Hi Doylen,
Yes i realised you were describing your fault to the original poster!
When he said his "Shrink ring" wasn't working properly, I took it to mean that it was fitted with some kind of turntable with sliprings - like the octopus.
Perhaps his problem has gone away, as he hasn't replied?
Perhaps i shouldn't have responded as there is so little information to go on as to who made the machine and what it does!!!
Anyway, all this talk of buns is making me hungry.
__________________
Last edited by Ned_Flanders; October 15th, 2009 at 06:07 AM. Reason: Bun talk has made me hungry!
Old October 15th, 2009, 06:44 AM   #9
robertmee
United States
robertmee is offline
robertmee's Avatar
If it has a shrink ring, it is likely a pallet shrink wrapper. We use them all the time in the Roofing Shingle industry to shrink an entire pallet of shingles as often the individual bundles are paper wrapped. Nowadays, more companies are going to individually plastic wrapped bundles, so the larger pallet wrappers aren't used as often.
Old November 5th, 2009, 02:47 PM   #10
sonarbell
United Kingdom
sonarbell is offline
If you need help Im a Robopac engineer,. Ask away
Old November 5th, 2009, 03:31 PM   #11
Ned_Flanders
England
Quote:
Thanks,
Have you been to any factories with large concrete silos recently?
__________________
Old November 5th, 2009, 03:34 PM   #12
silva.foxx
Wales
silva.foxx is offline
silva.foxx's Avatar
Handy to know for Helix and Genesis knowledge!!!
To OP: I don't honestly believe anyone can help without specifics ie the problem symptoms, machine info, what you suspect, what you've tried, etc...
Regards
__________________
silva.foxx
Simplicate, NOT complicate.
Old November 6th, 2009, 01:41 PM   #13
sonarbell
United Kingdom
I know Helix and Genesis intimately. Also a fountain of knowledge with Dimac machines too..
Whats your problem with the concrete factory. ?
Old November 6th, 2009, 01:52 PM   #14
Ned_Flanders
England
Sorry! the silos are MADE from concrete - they contain sugar. Just thought you might have paid a visit recently?
__________________
Old November 6th, 2009, 02:48 PM   #15
sonarbell
United Kingdom
Guess we are talking about the big factory next to the A14 ??
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
AB DH485 network problem rajsiyer LIVE PLC Questions And Answers 6 February 8th, 2008 09:00 PM
OMRON NT31c screen problem jugenzhu1963 LIVE PLC Questions And Answers 10 November 7th, 2006 03:54 PM
Ab Plc5 Rio Problem. fernandes LIVE PLC Questions And Answers 5 March 7th, 2004 01:25 PM
N8 file problem jimtech67 LIVE PLC Questions And Answers 2 February 6th, 2003 04:58 PM
N8 file problem LIVE PLC Questions And Answers 0 February 6th, 2003 07:36 AM
