plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old October 23rd, 2009, 09:43 AM   #1
The Plc Kid
United States
The Plc Kid is offline
The Plc Kid's Avatar
PID Single Loop Controller Vs. PLC
What are the pro's and con's of doing a psi or temp control pid loop in the processor vs a single loop controller?
Which method is best?
Old October 23rd, 2009, 09:54 AM   #2
curlyandshemp
Canada
curlyandshemp is offline
curlyandshemp's Avatar
In the PLC you can alter parameters based on what is happening in the process.
In some processes, such as sterilization of an HTST , differential level control loops in a flash chamber have different parameters for startup, cooldown and process.
Based on what the program is doing, parameters can be altered or the PID put in Manual Mode all under program control without an operator.
Advantage of stand alone PID controllers, the Auto Tune feature usually works.
__________________
Work to Ride,
Then Ride to Work
Old October 23rd, 2009, 10:06 AM   #3
The Plc Kid
United States
Is there an autotune for the plc pid loops. AB slc 5/04?
Old October 23rd, 2009, 10:35 AM   #4
curlyandshemp
Canada
No.
Only AB product with built in autotuning is the Contrologix PIDE instruction used in Function Block Diagram
__________________
Work to Ride,
Then Ride to Work
Old October 23rd, 2009, 12:57 PM   #5
russrmartin
United States
russrmartin is offline
Advantages
Kid,
There are advantages to both, and that really is why there are both. Typically the need for the autotune isn't required in the PLC, because the PLC controls the whole process, and at time the desired response from the loop controller is specific to the process. I've personally never used the autotune on the PIDE. Usually, if anything, I've seen PLC PIDs tuned to be overdamped, due to other conditions that made the overdamped response from the PID ideal for the process.
Russ
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Pid Loop Setup in PLC The Plc Kid LIVE PLC Questions And Answers 2 October 23rd, 2009 01:11 PM
How to implement PID in s7 300 PLC? amruthkiran LIVE PLC Questions And Answers 3 July 26th, 2009 11:17 AM
PID Controller problem, Please help! izzy prad LIVE PLC Questions And Answers 27 November 19th, 2008 06:43 PM
Accessing Simatic 505 PID Loop Avex LIVE PLC Questions And Answers 12 November 8th, 2005 02:44 PM
Practical PID Controller m_abd_el_khalik LIVE PLC Questions And Answers 0 January 22nd, 2004 03:25 PM
