TP177B and s7-1200 ?
Nov 2009
Texas
32
I need to figure out a workaround using a siemens TP177B with a s7-1200 plc. I cannot use a basic kpt600pn because siemens is backlogged for "unknown" reasons until jan-2010, go figure.
My question is there any way around this?;)
How to use a TP177 within S7 1200 Software?
OR does anyone know or have a KPT600PN that I can purchase if there is NO solution.
Thanks for your assistance.
Steve
Have you tried it using just the S7300/400 driver?
It works with 277/377's and their ethernet ports
WinCC Flex does not yet have drivers for S7-1200.
I doubt that the S7-300/400 driver can be used as the adressing is different.
If I understand correctly, then there does not exist an HMI solution at the moment for S7-1200. I find that so appaling that Siemens should find at least an interim solution for you. If I were you I would call my local Siemens dealer directly and explain that the current sitiation is unacceptable.
I have done it with a Redlion screen. I can address a 1200 using the S7-300 driver, I can access all tags and bits but cannot use the timer / counters in the RL so have to do this in the plc with a register. I had to turn off symbolic addressing and use it in a standard format ie DBx.DBx and then the RL driver worked ok.
You may find this is the same with the TP panel using a 300 driver.
That was interesting 504bloke.
What about rack/slot ? Is that 0/2 like S7-300 ?
From memory yes it was 0/2 but i'll check tomorrow when i'm in the office and let you know.
Oh and i was talking ethernet and not using any other comms modules on the 1200.
Anybody have experience with this combination? WinCCFlex 2008 is at SP2. The TP will not reliably communicate to the CPU (S7-1214) There is a...
2,047
Hi everyone I'm having trouble transfering a projec from my PC(wincc Flex 2008 sp2 Win7) to an HMI simatic panel(tp177b pn/dp 6"cstn). I 've...
3,527
Hello, as you might know, the TP177B is no longer in production. However, we do have a lot of them in our machines, so some spares would come in...
19
4,953
hello dear all. As a project the customer ask me to translate all texts to persian but the panel TP177B COLOR PN/DP shows squares instead of the...
1,300
Dear all, We have two machines and we have the same sytem running on the both, and TP177B 6" color HMI is installed on both, one of them got some...
2,522
