plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old December 8th, 2009, 07:02 PM   #1
a11anjones
United Kingdom
a11anjones is offline
Index Integer Bit will not hold a value?
Hi , I have a small problem with one of the integers that is storing a setting that is adjusted by an E700 HMI and stored in the programme.
The program stores this value in an index integer called #n12:75 and this value is copied to n7:5 where it used by the program,but the integer #n12:75 continues to hold the value 2 whatever value I enter in with the HMI.
Within another processor on the same network there is a similar instruction that performs the same task the integer #n16:75 holds a value that is copied to #n12:75, then copied again to n7:5 where it is used for a similar purpose as above- but this one works fine. The 2nd processor was an addition to the system and had a duplicated program to that above when the system was extended, this is why the addresses are similar.
Do the addresses of integers on two different processors conflict, I dont believe that they do unless they are told to. The program seems logical and there does not seem to be any conflicts. I have noticed that on the main processor which is at the end of the DF1 network that the links are removed from pins 1 & 2 and 7 & 8 on the DH485 connector, does this affect instructions
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
signed and unsigned guest LIVE PLC Questions And Answers 13 September 12th, 2017 01:45 AM
gray code 3 bit MAHER LIVE PLC Questions And Answers 13 April 25th, 2009 03:10 PM
installing a panelview 600 + rjmarinaro LIVE PLC Questions And Answers 10 June 17th, 2008 12:52 PM
Tidbits, finding the bit number or index Peter Nachtwey LIVE PLC Questions And Answers 10 February 9th, 2006 04:17 AM
1 bit from INT. Dutchass LIVE PLC Questions And Answers 10 November 18th, 2005 03:27 PM
