I am trying to write a HMI program using Panelbuilder32, for a new project, which has SLC 5/03 PLC, with 1747-SN scanner, for communicating with two Flex I/O racks (1794-ASB), and a Panelview 550.
Now the problem is I can't off first base, as when I create a basic Comms setup on the HMI, with a couple of tags on the screen (as a test), then try to "Validate All..", it comes up with
"Error 9075 Tag does not have a valid address in the terminals assigned Discrete Rack or Block Transfer Channels"
This happens even if I try to create the HMI program as laid out in the "Getting Started with PanelBuilder Software" manual.
I am using Panelbuilder32 v.3.80
Can anyone help?
Can anyone help?
